    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 10.4k Views 20 Watching
      kwistenbiebel
      Hi people,
      With all the talk going on about Sketchup needing multicore support to handle high polycount scenes(I agree with that by the way 😉 ), I did feel the need though to illustrate that rendering hugh polycount scenes is supported by some of the main render engines, by using the 'instancing/proxies' method.
      In a nutshell it means that one can populate a scene with the low-poly dummy alter ego of a high poly component..
      Currently (and correct me if I am wrong) three of the main renderengines support this feature, each using their own method: Indigo, Fry render and Kerkythea.
      I believe Maxwell supports it as well but only in the 'Studio', not through the SU plugin
      Some examples I made using Fry's proxy/instancing method:
      2500 dead trees :
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/dead-woodsmall.jpg
      Green trees:
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/tree-proxies.jpg
      rabbits?.... 😆
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/rabbitsb.jpg
      Cheers,
      Kwistenbiebel
        lewiswadsworth
        The full VRay plugin for 3DS Max (the one you get from Chaos Group)used to do this, and I assume still does. Unfortunately, it doesn't seem in the cards for ASGvis' version of VRay for SU.
        col sporcar si trova
          remus
          Nice rabbits 👍 wish i had the time to play around with tihngs like this 😉
          • F Offline
            FIRE1BULL
            Looking good! I really hope this will be supported to in the future of the excelent Podium plugin 😄
            Greetz...
            Johannes R.
            • N Offline
              notareal
              Instancing can really made a difference. It's like micropoly displacement, when you get used to it, you cannot live without it.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              • FrederikF Offline
                Frederik
                Looks great, Biebel..!! 😉
                Instancing sure is a nice feature... 😄
                Thanks for sharing the info on TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain...
                Hopefully the SU2KT plug-in will be able to have a similar feature in near future... Sure will be handy for high poly components, cause SU sure has an issue with this... 😐
                Cheers
                Kim Frederik
                • I Offline
                  ilay7k
                  don't forget D.Bur's Component Spray Tool!
                    kwistenbiebel
                    Oh...I need to check that one out !
                    Where can I find the ruby?
                    • marked001M Offline
                      marked001
                      i reeeeaallly wish the new maxwell plugin was ready, i spent alot of time last night trying to get a scene with a bunch of grass and trees to run....and kept crashing 😕 these are very cool 😄
                      http://www.revision21vis.com
                      instagram: revi21on
                      • soloS Offline
                        I really need to look into this instancing thing, they look so cool. I saw a render on the KT site once where a user populated a scene with a ridiculous amount of trees and it was awesome.
                        I like the dead trees above, the bunnies look very militant, almost threatening.... very cool.
                          A while ago I wrote Matrix+Proximity script.
                          Matrix lets you place 1d, 2d and 3d matrices of components, using randomized spacing, rotation or scaling - if desired. If you make these copies above a land-form then there's also a built in 'drop' function to plonk them down onto the ground sufrace.
                          Proximity works when you have three types of a component (e.g. tree1-, tree1~ and tree1+) that each have increasing amount of detail / polygons. So you model with the simple stick "tree1-", then when you want a detailed shadowed render you use it swap out any tree1's near to the camera with tree1+ and tree1~ in the middle-ground. A dialog lets you set ranges from the camera position for each. You can always swap all back to tree1- by setting the detail level to (near) zero...
                          It was the only way of using highly detailed components in large numbers without killing the processor. There could be many uses - landscape trees/bushes etc, people in crowds, cars in streetscapes, seats in stadia etc...
                          Generic 'simple' component use, with later swapping out seems the way forward ?
                            kwistenbiebel
                            @TIG,
                            I didn't have the chance to try out the 'matrix-proximity' plugin but I certainly will.
                            A little experiment on populating the Sharoun scene with proxies :
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/veggy-frenzyb-small.jpg
                            For the record: only 3 components were used.
                            When using proxy/instancing a degree of randomness seems to be easily accomplished, even with a low number of different tree components:
                            Too bad it is not possible to have the same view within Sketchup itself for e.g a hidden line SU render..... 😢
                            • I Offline
                              ilay7k
                              Jason, Pavol made new build of maxwell exporter?
                              biebel, great pic!
                              dark-green autumn(close) world
                                kwistenbiebel
                                Some roses added and a somewhat different tonemapping:
                                http://i140.photobucket.com/albums/r3/kwistenbiebel1/GREENSTUFF-fry1-smallc.jpg
                                Once you start using instances/proxies, you don't need to worry about polycount anymore in sketchup....that is if you are willing to give up the ability to have default sketchup image output. ( the dummies look like crap in your SU viewport 😉 )
                                  kwistenbiebel
                                  As a note,
                                  I used TBD's 'drop.rb' ruby to place the array of low poly dummies on the sloped terrain.
                                  The SU screen:
                                  The blue box shows one selected dummy. In this case,I replaced the high poly rabbit component with a dummy containing just 10 triangles. The dummy was copied 2500 times and the array dropped on the terrain;
                                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/proxies-su-screensmall.jpg
                                    kwistenbiebel
                                    This is a crop of the original sized image so you can see some of the veg in close-up:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/fragment-naturescene2.jpg
                                    • soloS Offline
                                      Dang!!!
                                      What app did you use? Fryrender?
                                      That is amazing.
                                        kwistenbiebel
                                        Thanks Pete,
                                        Yes, I used Fry render for this one. I let it render for about 4 hours, which I find acceptable for a complex scene like this to get it clean.
                                        I am not planning to render this with other soft (Indigo and KT has instancing too) as I would have to start again from scratch (they all have different methods of making proxies). 😉
                                        Cheers,
                                        Kwistenbiebel
                                        • FrederikF Offline
                                          Frederik
                                          http://www.kerkythea.net//users/Frederik/Anim-Icons/applause.gif
                                          Really impressive, Kwistenbiebel...
                                          http://www.kerkythea.net//users/Frederik/Anim-Icons/clap-above.gif
                                          Could fool many to believe this was a real photo... 😉
                                          Cheers
                                          Kim Frederik
                                            pibuz
                                            Hi master Kwisten 😄
                                            REALLY impressive images! I assume you've done an export from Sketch to fry, before the render: am i right?
                                            If so, i'd be very very very interested in how did you map the foliage on the plants and bushes. And I'd very like to know where the rose-bush component comes from...
                                            I've tried converting to ".3ds" some 3D trees i found for 3dsMax, but mapping every single leaf it's an endless work to do: how can you do that? If i can ask, obviously: this can be a little secret to keep, i'd understand you 😉
                                            Thank you so much, however!
                                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                            • 1 / 4
