    Fry- Indigo- Vray- Kerkythea- Maxwell- Podium (added page2)
    57 Posts 32 Posters 40.6k Views 32 Watching
    • david57D Offline
      david57
      Nice dark shadows on the Fry Render. Like this the best. For KT
      i reduce the shadow color value below 0, maybe -0.01, Sometimes.
        jasonh1234
        "If you increase the fremtion to 12 or so the THV will auto-adjust the kull weight of the spline. And cut your render time to half of that of what YEQ took."
        There! Now you know how I felt while I was trying to read all that. ๐Ÿ˜†
        I'm sure it will slowly start to make sense to me though.
        Thanks so much for posting the comparison shots. As someone who's just trying to get into rendering it's helpful to see the differences and hear (even approximately) the differences in render times.
        Check out my SketchUp iconpack. Available here.
        • N Offline
          nscheiter
          Hey Kwistenbiebel,
          Id be interested in hearing where you got those 3d landscape items from. Are they evermotion too? and the best way you got them into your scene.
          Good work my friend, good work.
          -Neill
            andeciuala
            great work, could you share that texture used on grass? please, its amazing.
              Loewenkatze
              Kwistenbiebel,
              really impressive work... and a pleasure to see which house you chose for that comparison...
              btw... what happened to the handrail of the balcony in the KT render? Did it get lost due to the ten different export-pieces from SU to KT?
              Cheers,
              Franziska
              "I think play is the most important thing in the world." [Jacques-Yves Cousteau]
              • DanielD Offline
                Daniel
                They look great, although if I had to pick one as my fav it would be the first - it just appears crisper to me. I also noticed the top rail is missing in the Kerky render.
                My avatar is an anachronism.
                • K Offline
                  kwistenbiebel
                  Thank you all for the kind remarks.
                  Indeed, I missed the handrail in the Kzrkythea export.
                  The vegetation is partially Evermotion, and partially 3Dwarhouse which I adapted to my taste.
                  I finally got the chance to render the scene with Podium.
                  So this is a little update.
                  PODIUM RENDER 1.5.1
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/SCHMINKE-HOUSE-SHAROUN-PODIUM-kl-1.jpg
                  • soloS Offline
                    solo
                    Thats awesome Biebel, if I was to choose the one I like best I'd probably be jeered off for being biased so I won't mention it. ๐Ÿ’š ๐Ÿ˜’
                    http://www.solos-art.com
                      DzineTech
                      I know what you mean as I'm biased to vray and its the image I like the best, although I would have used IR+LC for the render which I'm sure would yield a better image than the Universal settings. The Podium image is pretty nice though.
                        ScottPara
                        Hands down I think the podium render looks the best and has the best overall feel to it.
                        Scott
                        Love the fact that some HATE my avatar.....
                        • FrederikF Offline
                          Frederik
                          I agree with you on that, Scott...
                          However, when knowing that Kwistenbiebel used the v. 1.5.1, where Kerkythea is the engine behind, you can start wondering why the render made using KT wasn't looking that good... ๐Ÿ˜’
                          Both renders should be very close to identical..! ๐Ÿ˜‰
                          Cheers
                          Kim Frederik
                          • StinkieS Offline
                            Stinkie
                            I'm not altogether sure I like what you're implying. Kwisten's always done his best to advocate - be it in writing or by rendering - the qualities of all the rendering apps he uses.
                            Show some courtesy.
                            • tbdT Offline
                              tbd
                              ... mainly because Podium is not using the exact same Kerkythea engine as in KT.
                              nice work Biebel !
                              SketchUp Ruby Consultant | Podium 1.x developer
                              http://plugins.ro
                              • FrederikF Offline
                                Frederik
                                Sorry - but I don't know what or how you're interpreting what I've been writing...
                                I'm not trying to imply anything here... All I'm saying is that based on the fact that the engine running under the hood of Podium v. 1.5.1 is KT, the result should be fairly identical, but this is not what I've seen in this test... ๐Ÿ˜‰
                                ๐Ÿ˜• ๐Ÿ˜• ๐Ÿ˜•
                                TBD - you know that the core is identical, but maybe the settings are different, which's then showing in the result...
                                Nevertheless, I said that it should be very close to identical..! ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                • StinkieS Offline
                                  Stinkie
                                  Clearly, if I've misinterpreted what you said, then an apology is due. Consider this one.
                                  If.
                                  • FrederikF Offline
                                    Frederik
                                    No worries, Stinkie... ๐Ÿ˜‰
                                    Cheers
                                    Kim Frederik
                                    • StinkieS Offline
                                      Stinkie
                                      Allrighty then. Apologies! ๐Ÿ˜ณ ๐Ÿ’š
                                      • N Offline
                                        notareal
                                        I have to add that it's fairly pointless to made deep conclusions with these kind of comparisons, there always so much differences with render engines - even scenes and camera settings can be different, unintentionally. Passion towards one engine can lead different results. Anyhow, it's always interesting to see what one can do with different render engines. Usually in the end - conclusion is clear - use one that you happy with. โ˜€
                                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                        • N Offline
                                          notareal
                                          ๐Ÿ˜• ๐Ÿ˜• ๐Ÿ˜•
                                          I think difference do come from five different element, missing parts; handrail and 2th floor windows & interior and some missing stone decorations, different grass (or it's mapping), different tone mapping, different image size/ratio and far different render method. Podium uses Photon Mapping, if I have understood right, and with KT Kwistenbiebel used new MLT/BPT, that was not cooked long enough to clear noise. MLT/BPT is actually best suited for difficult indirect lighting conditions, that have hard to produce caustics, blurry reflections... what ever.
                                          Sorry for bad photoshopping, but had to add those missing handrail&window parts and change image size to reveal how great difference those do made. I remove this if needed.
                                          edit: oops... now I see I missed 1st floor handrail too. ๐Ÿ˜ณ
                                          • K Offline
                                            kwistenbiebel
                                            As a note, this thread is not meant to be a comparison as it was stated in the first post.
                                            :('This is not meant as a comparison thread between render engines. Just an exercise on using them.'
                                            Looks like some of you are making it into one ... ๐Ÿ˜‰
                                            • 2 / 3
