    Fry- Indigo- Vray- Kerkythea- Maxwell- Podium (added page2)
    57 Posts 32 Posters 40.3k Views 32 Watching
      kwistenbiebel
      Oops 😳
      Thanks for pointing this out Whaat.
      I only recently started using Indigo again as you know so I am still searching my way.
      When I find time (weekend?) I'll try your suggestion on the use of thin glass.
      Also it could be that I didn't use the best optimised render settings (I used 'hybrid') so maybe another setting will improve the render time.
      Cheers,
      Kwistenbiebel
      • W Offline
        Whaat
        Hybrid should theoretically be the fastest but it has been known to be one of the slowest (I don't think Onosendai has optimized it yet). I would try one of the other settings and compare the render times (if you can find the time this weekend... 😄 )
          lrsuser
          Nice exercise. I have been wanting to do something similar for a long time to better understand idiosyncrasies of diff. rendering engines, mainly indigo/vray/podium for me, but never found time...not even on a weekend.. 😄
          really impressed by vray time vs indigo time.
          • AnssiA Offline
            Anssi
            Kwistenbiebel,
            A great comparison. You seem to be a master of all rendering engines-the lighting was very realistic in every one. Only the Kerkythea one seemed to have too much light reflecting from the grass.
            All the similar comparisons I have seen in the past have shown the author to be either biased toward his/her favourite application, or then that he/she has clearly not known how to use some of them. This time this has not bee the case.
            I would like to hear your comments about the usability of the different systems, and how difficult you find the setting up required to get these outstanding results.
            Anssi
            • david57D Offline
              david57
              Nice dark shadows on the Fry Render. Like this the best. For KT
              i reduce the shadow color value below 0, maybe -0.01, Sometimes.
                jasonh1234
                "If you increase the fremtion to 12 or so the THV will auto-adjust the kull weight of the spline. And cut your render time to half of that of what YEQ took."
                There! Now you know how I felt while I was trying to read all that. 😆
                I'm sure it will slowly start to make sense to me though.
                Thanks so much for posting the comparison shots. As someone who's just trying to get into rendering it's helpful to see the differences and hear (even approximately) the differences in render times.
                Check out my SketchUp iconpack. Available here.
                • N Offline
                  nscheiter
                  Hey Kwistenbiebel,
                  Id be interested in hearing where you got those 3d landscape items from. Are they evermotion too? and the best way you got them into your scene.
                  Good work my friend, good work.
                  -Neill
                    andeciuala
                    great work, could you share that texture used on grass? please, its amazing.
                      Loewenkatze
                      Kwistenbiebel,
                      really impressive work... and a pleasure to see which house you chose for that comparison...
                      btw... what happened to the handrail of the balcony in the KT render? Did it get lost due to the ten different export-pieces from SU to KT?
                      Cheers,
                      Franziska
                      "I think play is the most important thing in the world." [Jacques-Yves Cousteau]
                      • DanielD Offline
                        Daniel
                        They look great, although if I had to pick one as my fav it would be the first - it just appears crisper to me. I also noticed the top rail is missing in the Kerky render.
                        My avatar is an anachronism.
                          kwistenbiebel
                          Thank you all for the kind remarks.
                          Indeed, I missed the handrail in the Kzrkythea export.
                          The vegetation is partially Evermotion, and partially 3Dwarhouse which I adapted to my taste.
                          I finally got the chance to render the scene with Podium.
                          So this is a little update.
                          PODIUM RENDER 1.5.1
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/SCHMINKE-HOUSE-SHAROUN-PODIUM-kl-1.jpg
                          • soloS Offline
                            Thats awesome Biebel, if I was to choose the one I like best I'd probably be jeered off for being biased so I won't mention it. 💚 😒
                              DzineTech
                              I know what you mean as I'm biased to vray and its the image I like the best, although I would have used IR+LC for the render which I'm sure would yield a better image than the Universal settings. The Podium image is pretty nice though.
                                ScottPara
                                Hands down I think the podium render looks the best and has the best overall feel to it.
                                Scott
                                Love the fact that some HATE my avatar.....
                                • FrederikF Offline
                                  Frederik
                                  I agree with you on that, Scott...
                                  However, when knowing that Kwistenbiebel used the v. 1.5.1, where Kerkythea is the engine behind, you can start wondering why the render made using KT wasn't looking that good... 😒
                                  Both renders should be very close to identical..! 😉
                                  Cheers
                                  Kim Frederik
                                  • StinkieS Offline
                                    Stinkie
                                    I'm not altogether sure I like what you're implying. Kwisten's always done his best to advocate - be it in writing or by rendering - the qualities of all the rendering apps he uses.
                                    Show some courtesy.
                                    • tbdT Offline
                                      tbd
                                      ... mainly because Podium is not using the exact same Kerkythea engine as in KT.
                                      nice work Biebel !
                                      http://plugins.ro
                                      • FrederikF Offline
                                        Frederik
                                        Sorry - but I don't know what or how you're interpreting what I've been writing...
                                        I'm not trying to imply anything here... All I'm saying is that based on the fact that the engine running under the hood of Podium v. 1.5.1 is KT, the result should be fairly identical, but this is not what I've seen in this test... 😉
                                        TBD - you know that the core is identical, but maybe the settings are different, which's then showing in the result...
                                        Nevertheless, I said that it should be very close to identical..! 😉
                                        Cheers
                                        Kim Frederik
                                        • StinkieS Offline
                                          Stinkie
                                          Clearly, if I've misinterpreted what you said, then an apology is due. Consider this one.
                                          If.
                                          • FrederikF Offline
                                            Frederik
                                            No worries, Stinkie... 😉
                                            Cheers
                                            Kim Frederik
                                            • 2 / 3
