    Problem with 2D PDF export.
    18 Posts 7 Posters 6.4k Views 7 Watching
    • Al HartA Offline
      Al Hart
      I am exporting a SketchUp model to PDF.
      When I load the PDF in adobe it appears properly, but when I do anything in Adobe (e.g. zoom), the image turns to white and I can't see anything.
      The drawing has text below the main drawing. If I remove the text before the export, then things seems to work OK. (I tried this with Adobe 8.1.0 and 8.1.2)
      Has anyone had a similar problem?
      test2.pdf is the one that fails
      test2.pdf
      test1.pdf is the one that works ok
      test1.pdf
      This is the SKP file:
      pdf-problem.skp
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • Alan FraserA Offline
        Alan Fraser
        It looks a little strange, Al. It opens for me in Photoshop, but only text and dim arrows...no drawing at all...and no background. Acrobat reports an error and refuses to open it.
        3D Figures
        • Al HartA Offline
          Al Hart
          Thanks for testing it Alan.
          I added the one that works as well (test1.pdf) and the .SKP file to the original message.
          I am just creating these with SketchUp 6.0 2D Export.
          Al Hart
          • AnssiA Offline
            Anssi
            I have Adobe Reader 8.1.1, and it is yhe same with me, when I open it it displays OK, but if I try to scroll or zoom the image disappears
            Is it a font problem?
            I have recently had some error messages when opening SU-exported PDFs with Adobe PDF 7 Professional too-they had something to do with fonts, even if the text should have been plain Arial
            Anssi
            • Al HartA Offline
              Al Hart
              I originally had a Tahoma font which created an error message when I loaded the PDF into Adobe. I switched to Times New Roman, and also checked: "Map Windows fonts to PDF base fonts".
              I just switched the fonts to Arial and tried it with the check box checked and unchecked, but it didn't help.
              Al Hart
                When I open them (both), there is a bounding box with dimensions and all but no drawing inside. AQny time I try to change the zoom level, everything disappears and I'm left with an empty page.
                • Al HartA Offline
                  Al Hart
                  OOF.
                  I think were going to have to give up on PDF and use an image of the screen instead.
                  However, that is a shame, because PDF format make much better printouts because of the increased resolution. 😢
                  Al Hart
                  • boofredlayB Offline
                    boofredlay
                    Have you tried using the PDF Creator and just printing to PDF?
                    Might give it a shot.
                      alpro
                      I just printed your skp to pdf995 and it opened in acrobat reader 8.1 just fine, was able to scroll and zoom.
                      Mike
                      • Al HartA Offline
                        Al Hart
                        I hadn't thought about an external PDF.
                        Does it create the PDF from vectors or a raster image?
                        Can you upload the PDF so I can check the quality?
                        Al Hart
                          alpro
                          Al, here you go.
                          Mike
                          pdf-problem.pdf
                            boofredlay
                            Glad to hear that worked. I cannot take the credit for the idea however. Thanks Jackson:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?p=40731#p40731
                            I like to use PDF Creator because you do not get any of the annoying pop-up ads. PDF995 had a ton when I used to use it.
                              alpro
                              Eric, I just paid the $10, now no more pop-ups. I don't have a plotter so I use it to print my cad drawings which I then take to Knikos.
                              Mike
                              • Al HartA Offline
                                Al Hart
                                Thanks,
                                The PDF you sent is pretty good quality, but it is "rasterized" and not a vector drawing.
                                You can see this because when you Zoom in the lines are jagged.
                                This is the PDF from SketchUp, zoomed in in Adobe. When you zoom the vectors are redrawn and don't get jaggy.
                                Still, it may be of good enough quality to work.
                                Another interesting thing is that the PDF you created to chopped off some of the text.
                                The Image on the top is from the PDF. The 20' is missing the bottom half of the text.
                                The image on the bottom is the SketchUp screen.
                                @alpro said:
                                Al, here you go.
                                Mike
                                Al Hart
                                  linea
                                  Al,
                                  I imported the skp into layout, then exported pdf, it worked fine.
                                  • AnssiA Offline
                                    Anssi
                                    When I export this, Adobe Reader shows the image for a short time, and then pops up this error message:
                                    The font 'Tahoma' contains a bad /Bbox
                                    It is the same that has been teasing me with my PDF exports lately, regardless of the fonts I use (I never use Tahoma, I hate it)
                                    If you want to export a vector file similar to the PDF export by using a PDF printer driver, you can check the "Use High-accuracy HLR" box in the Print dialog. I tried with my old Adobe PDF Writer, and I had no problem (except that it doesn't support large paper sizes)
                                    Anssi
                                      alpro
                                      Using Anssis suggestion produced a much better result.
                                      Mike
                                      pdf-problem.pdf
                                      • Al HartA Offline
                                        Al Hart
                                        This one zooms in much better and doesn't clip the 20' 😉
                                        Mike
                                        Al Hart
