    Problem with 2D PDF export.
    18 Posts 7 Posters 6.0k Views 7 Watching
      alpro
      I just printed your skp to pdf995 and it opened in acrobat reader 8.1 just fine, was able to scroll and zoom.
      Mike
      • Al HartA Offline
        Al Hart
        I hadn't thought about an external PDF.
        Does it create the PDF from vectors or a raster image?
        Can you upload the PDF so I can check the quality?
        Al Hart
        IRender nXt from Render Plus
          alpro
          Al, here you go.
          Mike
          pdf-problem.pdf
          • boofredlayB Offline
            boofredlay
            Glad to hear that worked. I cannot take the credit for the idea however. Thanks Jackson:
            http://www.sketchucation.com/forums/scf/viewtopic.php?p=40731#p40731
            I like to use PDF Creator because you do not get any of the annoying pop-up ads. PDF995 had a ton when I used to use it.
              alpro
              Eric, I just paid the $10, now no more pop-ups. I don't have a plotter so I use it to print my cad drawings which I then take to Knikos.
              Mike
              • Al HartA Offline
                Al Hart
                Thanks,
                The PDF you sent is pretty good quality, but it is "rasterized" and not a vector drawing.
                You can see this because when you Zoom in the lines are jagged.
                This is the PDF from SketchUp, zoomed in in Adobe. When you zoom the vectors are redrawn and don't get jaggy.
                Still, it may be of good enough quality to work.
                Another interesting thing is that the PDF you created to chopped off some of the text.
                The Image on the top is from the PDF. The 20' is missing the bottom half of the text.
                The image on the bottom is the SketchUp screen.
                @alpro said:
                Al, here you go.
                Mike
                Al Hart
                  linea
                  Al,
                  I imported the skp into layout, then exported pdf, it worked fine.
                  • AnssiA Offline
                    Anssi
                    When I export this, Adobe Reader shows the image for a short time, and then pops up this error message:
                    The font 'Tahoma' contains a bad /Bbox
                    It is the same that has been teasing me with my PDF exports lately, regardless of the fonts I use (I never use Tahoma, I hate it)
                    If you want to export a vector file similar to the PDF export by using a PDF printer driver, you can check the "Use High-accuracy HLR" box in the Print dialog. I tried with my old Adobe PDF Writer, and I had no problem (except that it doesn't support large paper sizes)
                    Anssi
                      alpro
                      Using Anssis suggestion produced a much better result.
                      Mike
                      pdf-problem.pdf
                      • Al HartA Offline
                        Al Hart
                        This one zooms in much better and doesn't clip the 20' 😉
                        Mike
                        Al Hart
