    Grid on Ground
    9 Posts 7 Posters 1.9k Views 7 Watching
      SpaceMan
      Can you make a grid on the ground? and the grid can be a point of color-coded feedback. The size of square is depend on the unit of the model. Unlike Ruby script 3D Grid, the grid is infinity-extended.
        Baker518
        If I recall, there are at least 3 different grids I have seen and it seems like they are size-able from a pop-up when you select them.
        Don't worry about things you have no control over. Worry is a lack of Faith!
        • EdsonE Offline
          Edson
          then define the origin, grid spacing and number of units in both directions.grid3.png
          http://www.mahfuz.arq.br
            Jim
            Hi Edson,
            You must have a "grid" plugin installed.
            • EdsonE Offline
              Edson
              yes, it is here for anyone to download. it is a free script called parametric grid.
              grid.zip
                Yes, there is one (lthough not like an infinite plane.
                I like it because when we dig at excavations, we usually work in 10m X 10m grids and when I get back to SU I can easily navigate within my model.
                  SpaceMan
                  So it's not infinte plane...
                  • G Offline
                    gata
                    The parametric grid script, like it's name implies, is parametric - infinitely editable. Select grid, r-click and Choose Edit Grid. From there you control the size of the grid and the individual grid increments.
                      alz
                      The ideal grid:
                      • it can be scaled by a hotkey which doubles in size
                      • it is infinite (no need to set distance points)
                      • it isn't an actual object in the Outliner
                      • it has line weighting (ie. every 4th or 8th line is darker/heavier)
                      • it adjusts its visual screen draw to prevent moiré patterns
                      • if in an orthogonal view, it covers the background (ie. front, top, right)
                      • it is tied into the snap distance and unit of measurement
                      Thoughts?
