    Creating planks on a circle
    13 Posts 4 Posters 896 Views 4 Watching
    • G Offline
      garfield
      Hi all,
      I'm wanting to draw up a wishing well I've been asked to make up and I'd love to draw it in sketchup first. I'm wondering how I would start a drawing like that? If I created a circle first and then used the push/pull tool to make it the desired height and then make a rectangle to the height and with of a plank to go around that circle?
      I've tried to attach a picture of my sketch to help explain exactly what I'm trying to achieve but can't do it, so some help with that as well please πŸ˜›
      Cheers
      Geoff
        Hi Geoff,
        I'm not sure I understand what you mean to model but is it something like this attatched?
        well.skp
        • G Offline
          garfield
          @gaieus said:
          Hi Geoff,
          Hi Gaieus, Mate I can't open the attachment you sent me as I have Sketchup 5. Is there some other way I can open the file?
          Cheers
          Geoff
            Attached in v5 format (still I1m not sure that I understood your question)
            well.skp
            • G Offline
              garfield
              Thanks Gaieus. Yes that's exactly what I want to achieve. How would I draw that? Is there a specific video tutorial for drawing something like that?
              Cheers
              Geoff
                Not really.
                This is like step by step:
                1. Draw a circle (remember it midpoint - in my example it was at the origin)
                2. push-pull it up
                3. turn hidden geometry on
                4. select one facet and turn into a component
                5. edit the component and push/pull its face out a bit (this is the thickness of the plank)
                6. delete the rest of the well (keep the bottom circle for water if you wish) and Copy/rotate the component around the midpoint of the circle.
                It takes longer to write it down than to make it.
                πŸ˜‰
                • G Offline
                  garfield
                  I really appreciate your help with this Gaieus. I'm about to hit the sack as it's getting late here, but I'll give it a crack tomorrow and I'll let you know how I got on.
                  Cheers
                  Geoff
                  • Alan FraserA Offline
                    Alan Fraser
                    An even easier method, if you wanted the planks to appear mitered ...as in barrel staves...would be to simply use a circle, as shown. If you wanted to show separation on the top edge, you just draw in the lines joining the outer and inner circles.
                    well.skp
                    3D Figures
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      If you want to avoid drawing the lines, suggested by Alan, one by one, see the attached SU file for ideas.
                      Wooden well.skp
                      • G Offline
                        garfield
                        Thanks Alan
                        • G Offline
                          garfield
                          @jean lemire said:
                          Hi folks.
                          Jean, I have Sketchup 5 and can't open the attachment.
                          Cheers
                          Geoff
                            Added v5 version
                            Wooden well.skp
                            • G Offline
                              garfield
                              @gaieus said:
                              Added v5 version
                              Thanks for changing that for me Gaieus, And thanks Jean for the tip.
                              Cheers
                              Geoff
