    Creating planks on a circle
    13 Posts 4 Posters 1.1k Views 4 Watching
      garfield
      Hi all,
      I'm wanting to draw up a wishing well I've been asked to make up and I'd love to draw it in sketchup first. I'm wondering how I would start a drawing like that? If I created a circle first and then used the push/pull tool to make it the desired height and then make a rectangle to the height and with of a plank to go around that circle?
      I've tried to attach a picture of my sketch to help explain exactly what I'm trying to achieve but can't do it, so some help with that as well please πŸ˜›
      Cheers
      Geoff
        Hi Geoff,
        I'm not sure I understand what you mean to model but is it something like this attatched?
        well.skp
          garfield
          @gaieus said:
          Hi Geoff,
          Hi Gaieus, Mate I can't open the attachment you sent me as I have Sketchup 5. Is there some other way I can open the file?
          Cheers
          Geoff
            Attached in v5 format (still I1m not sure that I understood your question)
            well.skp
              garfield
              Thanks Gaieus. Yes that's exactly what I want to achieve. How would I draw that? Is there a specific video tutorial for drawing something like that?
              Cheers
              Geoff
                Not really.
                This is like step by step:
                1. Draw a circle (remember it midpoint - in my example it was at the origin)
                2. push-pull it up
                3. turn hidden geometry on
                4. select one facet and turn into a component
                5. edit the component and push/pull its face out a bit (this is the thickness of the plank)
                6. delete the rest of the well (keep the bottom circle for water if you wish) and Copy/rotate the component around the midpoint of the circle.
                It takes longer to write it down than to make it.
                πŸ˜‰
                  garfield
                  I really appreciate your help with this Gaieus. I'm about to hit the sack as it's getting late here, but I'll give it a crack tomorrow and I'll let you know how I got on.
                  Cheers
                  Geoff
                  • Alan FraserA Offline
                    Alan Fraser
                    An even easier method, if you wanted the planks to appear mitered ...as in barrel staves...would be to simply use a circle, as shown. If you wanted to show separation on the top edge, you just draw in the lines joining the outer and inner circles.
                    well.skp
                    3D Figures
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      If you want to avoid drawing the lines, suggested by Alan, one by one, see the attached SU file for ideas.
                      Wooden well.skp
                        garfield
                        Thanks Alan
                          garfield
                          @jean lemire said:
                          Hi folks.
                          Jean, I have Sketchup 5 and can't open the attachment.
                          Cheers
                          Geoff
                            Added v5 version
                            Wooden well.skp
                              garfield
                              @gaieus said:
                              Added v5 version
                              Thanks for changing that for me Gaieus, And thanks Jean for the tip.
                              Cheers
                              Geoff
