    Short wish list
    8 Posts 6 Posters 2.1k Views 6 Watching
    • Z Offline
      zero
      I have two item wish list for sketchup 7
      first : please,please,please inference forcing for draw circle
      i like to be able to start circle at the end of a line
      and very often i have to draw a cube just to lock the
      circle in the way i want .
      last : could be useful to have the possibility to create shortcut
      for right click context menu .I very often loose many line
      selection (ex: railing in staircase) in right clicking just
      off the line.
      thats all folks
      • G Offline
        gata
        There's the script SelectionMemory2 http://www.smustard.com/script/SelectionMemory2 and SelectionMemory at the same site to recall most recent selections.
        • plot-parisP Offline
          plot-paris
          would be great to have a selection memory function within SketchUp.
          just press the Alt key while using the Selection tool (that one is still free 😄 ) to flick trough your last selections. would be really great, because it is indeed anoying to lose complicated selection.
          • Y Offline
            yaakovraskin
            on thaty note it would be useful if there was a shortcut to explode a group, and another to open it also
              plot-paris
              I have set up a shortcut for expolding grous/components.
              • "G" = make Component
              • "Ctrl+G" = make Group
              • "Shift+G" = explode Group/Component
              it is really great - I use it all the time (increased my working speed by 5%) 😄
              but what do you mean with "open a group"? you only need to double click it...
              • Y Offline
                yaakovraskin
                i didnt notice in the prefrences the option of explode to put a shortcut. can you tell me where on that list it is please?
                  remus
                  important step First select a group, then go to window->preferences->shortcuts, thne in the filter bar edit->item(might be context?)->explode
                  using this method you can assigon shortcuts to everything in the context menu, if oyu want to.
                    rhankc
                    zero, check out Selection Memory 2 if you hadn't found it already.
                    Hank
