    Old and dirty render
    11 Posts 8 Posters 1.6k Views 8 Watching
    • E Offline
      eldar
      Hi! this is my new render very different of my usual work, render engine: v-ray set primary and secondary engine: ligth cache, no ligths, small size= very quick render. πŸ‘ sucio final copy.jpg
      I satarted ( in case you whant to know how i did it πŸ˜’ ) with a simple room and add dirty textures. original.jpg
      Then with the unfold.rb y flatten the model and export as a jpg (left), then open in photoshop and make more dirty and less patern textures (rigth). texturas.jpg
        remus
        wheres the pics?
        • E Offline
          eldar
          Finally remplace the textures whit the new one and render (image bellow), the finally image (firts in this post)is the result of retouching in photoshop for the rigth look = contrast,burn and desaturate. Hope you find this information useful!
            dylan
            Thanks eldar, I certainly find this info very useful and I will give it a try.
            Render looks good, it's a change from the usual stuff.
            http://dmdarchitecture.co.uk/
            • P Offline
              Phil Rader AIA
              sorry I just felt your image was missing something. Hope you don't mind the embellishment
              http://www.philrader.com
              • G Offline
                goodonline
                I think vray does an awesome job with sketchup. I used vray in the past with Max and had great success fooling my clients if it was real or a rendering.
                Is it possible to add bump maps in your rendering with vray? I have not used it with sketchup as of yet, and haven't seen the interface within sketchup. Is there a material editor for / within sketchup?
                Robert Good
                http://www.digitalnursery.net
                • marked001M Offline
                  marked001
                  very cool.. did not know about that ruby.. very helpful.. very cool render too..
                  http://www.revision21vis.com
                  instagram: revi21on
                    DzineTech
                    Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)
                    • G Offline
                      goodonline
                      Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)[/quote]
                      If Vray would offer mapping capabilities within sketchup, I would re-invest in the plugin
                      i m m e d i a t e l y.
                      Robert Good
                      • E Offline
                        eldar
                        Displacement....have you tried crazybump?
                        it seems a good program to make displacement maps, this is the web: http://www.crazybump.com/
                          tomsdesk
                          Very cool process to make such lovely images...quite a secret you've shared, thank you very much for both!
                          2.5D Trees & Shrubs!
