    Old and dirty render
    11 Posts 8 Posters 1.8k Views 8 Watching
    • E
      eldar
      Hi! this is my new render very different of my usual work, render engine: v-ray set primary and secondary engine: ligth cache, no ligths, small size= very quick render. πŸ‘ sucio final copy.jpg
      I satarted ( in case you whant to know how i did it πŸ˜’ ) with a simple room and add dirty textures. original.jpg
      Then with the unfold.rb y flatten the model and export as a jpg (left), then open in photoshop and make more dirty and less patern textures (rigth). texturas.jpg
        remus
        wheres the pics?
        • E
          eldar
          Finally remplace the textures whit the new one and render (image bellow), the finally image (firts in this post)is the result of retouching in photoshop for the rigth look = contrast,burn and desaturate. Hope you find this information useful!
            dylan
            Thanks eldar, I certainly find this info very useful and I will give it a try.
            Render looks good, it's a change from the usual stuff.
            http://dmdarchitecture.co.uk/
            • P
              Phil Rader AIA
              sorry I just felt your image was missing something. Hope you don't mind the embellishment
              http://www.philrader.com
              • G
                goodonline
                I think vray does an awesome job with sketchup. I used vray in the past with Max and had great success fooling my clients if it was real or a rendering.
                Is it possible to add bump maps in your rendering with vray? I have not used it with sketchup as of yet, and haven't seen the interface within sketchup. Is there a material editor for / within sketchup?
                Robert Good
                http://www.digitalnursery.net
                • marked001M
                  marked001
                  very cool.. did not know about that ruby.. very helpful.. very cool render too..
                  http://www.revision21vis.com
                  instagram: revi21on
                    DzineTech
                    Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)
                    • G
                      goodonline
                      Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)[/quote]
                      If Vray would offer mapping capabilities within sketchup, I would re-invest in the plugin
                      i m m e d i a t e l y.
                      Robert Good
                      • E
                        eldar
                        Displacement....have you tried crazybump?
                        it seems a good program to make displacement maps, this is the web: http://www.crazybump.com/
                        • T
                          tomsdesk
                          Very cool process to make such lovely images...quite a secret you've shared, thank you very much for both!
                          2.5D Trees & Shrubs!
