    Old and dirty render
    11 Posts 8 Posters 1.8k Views 8 Watching
      remus
      wheres the pics?
      • E
        eldar
        Finally remplace the textures whit the new one and render (image bellow), the finally image (firts in this post)is the result of retouching in photoshop for the rigth look = contrast,burn and desaturate. Hope you find this information useful!
          dylan
          Thanks eldar, I certainly find this info very useful and I will give it a try.
          Render looks good, it's a change from the usual stuff.
          http://dmdarchitecture.co.uk/
          • P
            Phil Rader AIA
            sorry I just felt your image was missing something. Hope you don't mind the embellishment
            http://www.philrader.com
            • G
              goodonline
              I think vray does an awesome job with sketchup. I used vray in the past with Max and had great success fooling my clients if it was real or a rendering.
              Is it possible to add bump maps in your rendering with vray? I have not used it with sketchup as of yet, and haven't seen the interface within sketchup. Is there a material editor for / within sketchup?
              Robert Good
              http://www.digitalnursery.net
              • marked001M
                marked001
                very cool.. did not know about that ruby.. very helpful.. very cool render too..
                http://www.revision21vis.com
                instagram: revi21on
                  DzineTech
                  Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)
                  • G
                    goodonline
                    Yes and Yes. Displacement is also a feature along with many many more features. The material editor work in conjunction with SU because VfSU relies on SU for UV mapping (at least for now!)[/quote]
                    If Vray would offer mapping capabilities within sketchup, I would re-invest in the plugin
                    i m m e d i a t e l y.
                    Robert Good
                    • E
                      eldar
                      Displacement....have you tried crazybump?
                      it seems a good program to make displacement maps, this is the web: http://www.crazybump.com/
                      • T
                        tomsdesk
                        Very cool process to make such lovely images...quite a secret you've shared, thank you very much for both!
                        2.5D Trees & Shrubs!
