    Accessing the PDFs with Plugins
    9 Posts 5 Posters 1.5k Views 5 Watching
      I just had a thought. With many of the excellent Rubies you gurus are writing, you're also including PDF files with instructions. I was thinking it would be nice if they could be accessed directly from a menu entry in the Help menu. I'm picturing a menu entry with a flyout menu listing the PDF files that are included in the Plugins folder. At least that's where I end up extracting those files to when I unzip.
      Is this possible? I have no clue but it seems like it ought to be a short script. What say the experts?
      • AdamBA Offline
        AdamB
        Nice idea. And trivial to do.
        dialog = UI::WebDialog.new
        dialog.set_url "filepath_to_document.pdf"
        dialog.show
        Voila!
        FWIW I think the WebDialog is a really underused facility of SU - it opens up all the functionality of your browser to SU.
        • Didier BurD Offline
          Didier Bur
          I'll try to package that in a more user-friendly rb
          Thank for the tip Adam !
          DB
            Didier Bur
            Done,
            Go here to download:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=5421
            DB
            • fredo6F Offline
              fredo6
              Didier,
              Very nice idea.
              It seems to have problems with the subfolders of the Plugins directory however. For instance with the PDF of Bezierspline which are in subfolder BZ_DIR. I think it is because the file name contains a '.' (on top of the extension).
              Also, do you understand why the combo boxes in Sketchup Dialogs are never properly sized? I came across this problem too.
              • AdamBA Offline
                AdamB
                I you want nice (well nicer) dialog boxes you could do a html/js one using WebDialog 😄
                AdamB
                • fredo6F Offline
                  fredo6
                  Adam,
                  You are right, we can do much cooler things, but there is still the problem of compatibility with v5.
                  But I still don't understand the logic of the basic Sketchup Windows-based dialogs for dimensioning combo boxes!
                    azuby
                    OK guys, have a second look to Didiers download thread. I also tried to program an extension, but my solution creates a nested menu.
                    azuby
                      Didier Bur
                      Yes, the size problem is strange. I know that when you put more spaces in the prompt value it works
                      prompts=["help file............"]
                      but why this ? No logical explanation...
                      DB
