Accessing the PDFs with Plugins
9 Posts 5 Posters 1.1k Views 5 Watching
    I just had a thought. With many of the excellent Rubies you gurus are writing, you're also including PDF files with instructions. I was thinking it would be nice if they could be accessed directly from a menu entry in the Help menu. I'm picturing a menu entry with a flyout menu listing the PDF files that are included in the Plugins folder. At least that's where I end up extracting those files to when I unzip.
    Is this possible? I have no clue but it seems like it ought to be a short script. What say the experts?
      AdamB
      Nice idea. And trivial to do.
      dialog = UI::WebDialog.new
      dialog.set_url "filepath_to_document.pdf"
      dialog.show
      Voila!
      FWIW I think the WebDialog is a really underused facility of SU - it opens up all the functionality of your browser to SU.
        Didier Bur
        I'll try to package that in a more user-friendly rb
        Thank for the tip Adam !
        DB
          Didier Bur
          Done,
          Go here to download:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=5421
          DB
          • F Offline
            Didier,
            Very nice idea.
            It seems to have problems with the subfolders of the Plugins directory however. For instance with the PDF of Bezierspline which are in subfolder BZ_DIR. I think it is because the file name contains a '.' (on top of the extension).
            Also, do you understand why the combo boxes in Sketchup Dialogs are never properly sized? I came across this problem too.
              AdamB
              I you want nice (well nicer) dialog boxes you could do a html/js one using WebDialog 😄
              AdamB
              • F Offline
                Adam,
                You are right, we can do much cooler things, but there is still the problem of compatibility with v5.
                But I still don't understand the logic of the basic Sketchup Windows-based dialogs for dimensioning combo boxes!
                  azuby
                  OK guys, have a second look to Didiers download thread. I also tried to program an extension, but my solution creates a nested menu.
                  azuby
                  *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                  Bad English? PM me, correct me. :smile:**
                    Didier Bur
                    Yes, the size problem is strange. I know that when you put more spaces in the prompt value it works
                    prompts=["help file............"]
                    but why this ? No logical explanation...
                    DB
