KT
Tree Trunk, Branches,and 10 Leafs were made with a Blender script called Gen3.
Made Components with Trunk, Branches, and only 10 Octagon Leafs in SU.
The same Ten Leafs were used for the Hedges, but smaller.
Two more.
Here,s another render.
Model in the background was not made by me.
Model can be found at
http://archidom.net/ddd/model_S.htm
Needs Pillars or Columns under the radius.
Trying to figure this one out, before a render. Need to remove the door ways
on the first floor, they look like men and women restrooms.
Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
have the guts.
Never mind. Toilets/bathrooms are always needed.
But how come that tree is growing from the pavement?
Nice render BTW
Here's a test render with lots of mistakes.
Another test render.
by misstakes u mean the plants rite??? u just need a png image and turn on the alpha map in the clipping option!
Well, I'm just trying to keep up with Jone's and the Smiths.
Another render of Blenders Lsystem Trees.
Two more renders. Imported trees into SketchUp and separated some twigs
from the branches and trunk.
Populated the twigs with the same leafs i used for the hedges.
and a another...
Here's an 11,000 polygon tree. Small enough to work with SketchUp.
Using a small laptop, 797 MHz, 512 MB of RAM.
