    PathCopy not showing
    6 Posts 3 Posters 575 Views 3 Watching
    • EdsonE Offline
      Edson
      RickW or some other helpful soul,
      i have installed PathCopy by unzipping the file inside the plugins folder. it resulted in a folder that contains 3 files. however, it does not show in the plugins menu. what could be happening?
      yes, i closed SUp after installing. should pathcopy.rb be moved to outside of the folder?
      perhaps you should know i am on mac.
      thanks.
      http://www.mahfuz.arq.br
        RickW
        correct, the two .rb files and the "icons" folder should be directly in the "Plugins" folder, not in a subfolder.
        RickW
        [www.smustard.com](http://www.smustard.com)
        • EdsonE Offline
          Edson
          thanks, rick. the tools have appeared in the plugin menu but nothing happens to the cursor.
          where should pathcursor.png be? directly in the "Plugins" folder? inside the Icons folder or outside it?
            Edson, On my PCs, the PNG file is in a folder under Plugins called Icons. I imagine it should work the same way for the Mac but I haven't tried that.
            • EdsonE Offline
              Edson
              dave,
              that is how i have it in my mac. the script works fine, no more problems there, but there is no change in my cursor when i activate it.
                RickW
                I'll have to check - I may have hard-coded an expected (PC) path that will be different for Mac. Regardless, the script should work, even without the cursor change.
                RickW
