    Wanting to "Bend" Objects
    15 Posts 7 Posters 3.1k Views 7 Watching
    • Alan FraserA
      Alan Fraser
      This is a matter of procedure...doing things in the right order. Unfortunately, you can't bend what is effectively a perforated single surface.
      What I would suggest you do is create a "Checkerboard" TIN using the Sandbox tools, then...still using the sandbox...bend it the way you want. At this stage it will still be a single skin with no thickness.
      The TIN will be made up of many squares with diagonals. You can simply delete some to create the perforations or push cubes through the surface and physically cut holes using Intersect with Model.
      Lastly, use the ruby script Vector Push/Pull to pull the single surface into a true 3D one.
      Good luck.
      3D Figures
        mlammert
        Thanks for your quick response, Alan...
        I see what you mean by using the Sandbox and I have read up on that Ruby script and will download soon...
        Couple more related questions for you or whomever:
        The screenshot I sent was quite basic... What if I had a more complex shape (not created yet just in my head) like a 3D circuit board (copper traces are "pulled" above the green board) or something not necessarily "rectangular" (like a star or oval or something)...
        How would/could I go about "bending" something like that???
        Thanks,
        Mark
        • F
          fbartels
          Mark, Something like this? File is attached if interested. Fred
          raised bars.skp
            mlammert
            That is EXACTLY along the lines of what I was thinking of creating, Fred...
            Do you have a tutorial on how to create something like that???
            That is awesome!!!
            Thanks,
            Mark
            • F
              fbartels
              Mark,
              I made a little video here that explains the process. It may take a few seconds to download.
              Fred
                RegH
                Darn Fred, what the heck is that- some kind of a brassiere? Cool!
                • F
                  fbartels
                  Now that you mention it ... 😉
                    mlammert
                    Hey Fred,
                    Finally had a chance to go through the video you created and had great success... Thank you SO much for creating that tutorial for me...
                    I am going to keep practicing this...
                    My next desire is to create curves and circles on the TIN surface and "bend" those...
                    Thanks again,
                    Mark
                    • F
                      fbartels
                      Mark,
                      Here is one method to mix shapes (circles, stars, whatever) on a TIN along with raised bars, as shown in this image:
                      1. Prepare a TIN with bars or curved bars as described in the tutorial and previous posts.
                      2. Before ungrouping the objects duplicate just the "base" TIN directly down. You don't need to move it down too far, just far enough so that when you smoove the original the curves don't bump into the duplicate.
                      3. Ungroup all the objects.
                      4. Draw a vertical line from a corner of the original TIN to the matching corner of the duplicate TIN. This connects the TINs so that anything you do with Smoove to one will be done to the other.
                      5. Do your smooving.
                      6. Now select the duplicate TIN, copy it, open a new file, and choose Paste In Place.
                      7. In the new file, duplicate the TIN again, but this time moving the copy directly up. Move it up as far as you want the vertical thickness of the new object to be.
                      8. On a flat surface directly above the TINs draw the outline of the shape you want. Make sure it is a closed shape.
                      9. Using Push/Pull push the shape down through both TINs.
                      10. Intersect the two TINs and the shape, remove all the geometry you don't want, select the resulting shape, group it, copy it, then use paste in place to get it back into the original model.
                      11. Move the new object directly up until it sits on the original TIN.
                      • K
                        kwistenbiebel
                        Wow, it seems I still have to learn a lot about modeling even when I am using sketchup for almost 5 years now.
                        Sorry for the biggest Noob question of all time: What does TIN stands for?
                        • soloS
                          Triangulated Irregular Network
                          • StinkieS
                            Stinkie
                            That's beautiful. If I ever have a daughther, I'm gonna call her that.
                              mlammert
                              Thanks again Fred for your continued support on my question...
                              I am hopefully going to spend some time this weekend processing all that you have written and try to get some test files created...
                              Thanks again,
                              Mark
                              • F
                                fbartels
                                Mark
                                This was done quickly with a low-poly count so the curves are not as smooth as they could easily be. It was made by placing TIN beams on a vertical TIN surface and then using Smoove to curve the beams in the vertical plane. When I had the curves I wanted I rotated everything together back to the horizontal plane... did the various other steps in the tutorial, etc.. For other shapes you could either build them from TINs or use intersect as described in Alan Fraser's original response. Good luck!
                                curved lines on surface.skp
