    New script: Projection toolbar update
    25 Posts 12 Posters 7.3k Views 12 Watching
    • O
      otb designworks
      When I click on the link in the first post, I am receiving a note that that topic does not exist.
      Is there somewhere else I can download this update?
      Thanks Didier, your projection tools are awesome!
      Cheers, Chuck
      OTB Designworks is on Youtube
      • Didier BurD
        Didier Bur
        Probably a "board migration issue" 😲 ?
        The link has been fixed. You can also download all latest versions of free scripts at my site 😄
        Regards,
        DB
        • O
          otb designworks
          Thank you, sir.
          Works great now.
          Cheers, Chuck
            a4chitect
            didier great work! works perfectly and the user friendliness is sketchup-quality, please think about revising your lines2cyl script - it proves valuable when creating nets or simple structural grids.. thanks
            • GaieusG
              Regards,
              Sorry...
              • P
                pallamand
                Hi:
                Is there any required file to work with Projection?
                I can't make it work !!!
                I'm receiving from the ruby console:
                Error: #<NameError: uninitialized constant AddCpointTool>
                C:/Archivos de programa/Google/Google SketchUp 6/Plugins/projection_extension.rb:32
                C:/Archivos de programa/Google/Google SketchUp 6/Plugins/projection_extension.rb:32:in `call'
                when trying to place a construction point...
                Thank you
                Pablo
                • Didier BurD
                  Didier Bur
                  @ Pallamand,
                  This looks like an installation issue. Check for required subfolders an required files as well (see user guide). If everything is OK, tell me.
                  DB
                  • P
                    pallamand
                    Hi Didier:
                    Here are snaps of my directories...
                    Thank you once again for your help
                    Pablo
                    • Didier BurD
                      Didier Bur
                      Everything seems correct 😲
                      Error; #<NameError; uninitialized constant AddCpointTool>
                      means that the AddCpointTool class is unknown to SketchUp, and that the projection.rb file has not been loaded.
                      Let's try something. Open the Ruby console, select a line in your model and click with the cursor in the white field at the bottom of the ruby console and type:
                      Sketchup.active_model.select_tool ExtrudeLineTool.new (and hit Enter)
                      This launches the "extrudeline" tool. If you get an error message, be sure the script is not loaded. If it works, this is another problem (that I can't figure out for now...)
                      Hope this helps,
                      DB
                      • P
                        pallamand
                        Hi:
                        It seems it's working...
                        BTW, did I tell you that I can't use the "construction point" neither?
                        Thank you again for your help !!!!
                        Pablo
                        • simon le bonS
                          simon le bon
                          Dear Didier,
                          Un très grand bravo et un merci de la même taille pour ce "Projection Pack". I keep it as a permanent basic tools pack of SU.( And i haven't yet tapped quarter of its possibilities.)
                          One question:
                          Construction point is a very handy tool i am using daily. How can we do to erase them after the drawing is finished???
                          slb
                            a4chitect
                            edit>delete guides
                            • simon le bonS
                              simon le bon
                              "Bon sang mais c'est bien sûr"
                              (good blood but it's for sure)(does it mean something in english?) ;-)slb
                                (good blood but it's for sure)(does it mean something in english?) 😉slb
                                Damn me ! But it's obvious ! is nearest ? ...
                                  Dear Didier
                                  Does it possible for the N°13 (extrude selected lines along a vector) to have automatic new lines result "selected" for a new extrusion and so one... ☀
                                  So user has just to draw a line of vectors click after click 😉
                                  or such plug yet exist?
                                    @Tig
                                    Yes that is very nearest 😄
                                    From an old french TV Serial "5 dernières minutes" (Last five minutes) (like Colombo)
                                    And the gimmik was at the end "Mais bon sang, c'est bien sûr" when the Police superintendants Bourrel and his loyal Cabrol has found the solution of the crime! (It's Cabrol who said the gimmick 😄
                                    http://membres.lycos.fr/jchsaunier/hpbimg/BOURREL.jpg
                                    remake in comics by Gotlib : Bougret & Chabrol 💚
                                    http://img.over-blog.com/388x408/0/31/92/83/images16/RAB-Bougret-Charolles-bye.jpg
                                    And for my little suggestion above no idea?
