    Print to scale - but not using Standard views
    41 Posts 7 Posters 2.1k Views 7 Watching
      No, do this:
      • align the axes to the object
      • select the parallel projection (and don't do the scene update yet - Wodan was meaning that).
      • go to top view
      • click on one of the horizontal (R/G) axes.
      • pan and zoom as needed.
        😳 Still isn't getting it... 😞
        I tried following the steps to the letter, but I can't do the second last point as described. Simply clicking the axis doesn't do anything. I assumed you meant right-click and align view. But when I do that "Top" disappears from the upper left part of my viewport.
        Also, when am I suppose to update the scene?
          I retried and the TOP didn't disapper. Did it align your object however?
          And only refresh your scene when you have the view that you want (at the end).
            It did align the view to face the my object. But the result where just the same as when I select a face and choose "Align View"; I end up not in a standard view and can't print to scale.
            ... what SU version do you have? Mine is SU Pro 6.4.112
              Did you also right click on the axis (say red) and aligned the view to that?
              I don't know where you are missing the point. 😳
                Yes, after I'm in parallel Top view I right click the axis and Align View. That's when the "Top" text in the upper left part of the viewport disappears.
                Thanks for trying to help me out, but it seems my brain just can't wrap itself around this. Feels like a Monday...
                • Wo3DanW Offline
                  Wo3Dan
                  Thomthom,
                  sorry, I was away for a while reading other things blablabla....
                  I updatet the text a bit, hoping it will be clearer now:
                  @wo3dan said:
                  Try this to see if it works.
                  • For each face (to be printed later) create a scene in which you have the Blue axis running 'down' towards the face that you want in front view. (don't save yet, well you may)
                  • Select 'Parallel Projection' (you only need to save or update when you temporarely want to switch to another scene. Ultimately you only need one scene for each face) (so do not save yet, you may)
                  • And right click on one of the rotated axes will let you choose 'Align View', (learned that from Suzan, thanks).
                    The origin will be in screen center and you will be looking 'down' on that particular face.
                  • Pan and zoom to right view/position.
                  • Now save (or update) this scene ('as a new style') with the right scene name as a scene, for use any time.
                    (in top of the screen (left) you will see 'Top')[/color]
                  I hope this will do the trick. (try with one first)
                  Wo3Dan
                    I'm posting step by step screenshots of what I do.
                    My test model
                    I right click the axis -> Place to position it
                    more coming...
                      This is how I positioned the axis
                      more coming...
                        I select Parallel Projection
                        Then go to standard Top view
                        more coming...
                          Then I right click the green axis and Align View
                          This the result.
                          End of screenshots.
                            Well, the very last image is obviously not TOP view. The problem is that you aligned the axes to the house wrong. Align the green and red axes to two sides of the base line (horizontally) by clicking on one of the lower corners first to establish the origin and another lower corner second to establish the red axis. Now you may need to click again to the same poit to finish the alignment.
                            NOW right click on either the R/G axes and align the view.
                            • Wo3DanW Offline
                              Wo3Dan
                              Thomthom,
                              Please see updated text above.
                              And you aren't supposed to use the 'Views' icons to get this working for they
                              always use the original (unrotated) axes, no matter what!
                              It's about 'Align View' on (rotated) axes and Blue running 'down' in the right direction when applying this alignment!
                              Wo3Dan
                                rsw
                                I'm having trouble getting this to work as well - I'm sure I'm following your instructions properly, but I'm obviously missing something or doing something wrong.
                                Richard
                                  lewiswadsworth
                                  The trick that generally works for me is to put a section plane in the model, even if I don't plan on using it (put it well ahead of geometry if you don't want a section slice). I right-click on the visible section plane and choose "Align View." If I go to a print dialog then, with the camera view aligned to the section, I probably will still not have a non-grayed option for scaled output...unless I click the little box in the lower right corner for "2-D Section Slice Only." Then I can input a scale.
                                  It is important, after putting the scale in, to un-check that box. The option for scaled input returns to grayed-out, but it holds the value I put in when it was just a section-cut-only print. And if "Fit to Page" and "Model Extent" are both NOT checked, the resulting output will be at the scale I specified a moment ago for that section slice.
                                  I just tried it...yep, it still works.
                                  col sporcar si trova
                                    Ok, when I set the axis I start at the bottom left corner of the model and then click on the right bottom corner, this sets the red axis. I then click once again and the axis is set. I right click the axis and align view and I'm then into a "Top" view where the model is squared up. So far so good,
                                    However, I'm seeing the top of the house. I don't see how I can align the axis so I end up seeing one of the sides...
                                    Sorry for keep asking the same questions guys.
                                      ThisI managed to get working! 😍
                                      Though I can't work out why I couldn't get the other method to work...
                                      Either way. I'm going to post in the request forum and really REALLY hope scale printing is improved and made easier in coming versions of SU.
                                        Ahha. Tricky, now I cannot do that either (only top view seems to work). Hm... Let me try...
                                        • Wo3DanW Offline
                                          Wo3Dan
                                          Thomthom,
                                          see attached file.
                                          remember that red is left to right and green is to top unless you need a different orientation for the print. (That's the drawback with the section plane methode)
                                          Wo3Dan
                                          align A and B in frontview.skp
                                            rsw
                                            I can get the section plane method to work aswell, but I still can't get the other method to.
                                            I have downloaded your file Wo3Dan but the 'B=frontview' scene still cannot be printed to scale (the options are greyed out)?
                                            Richard
                                            • 1 / 3
