    โš ๏ธ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Transparent material
    4 Posts 4 Posters 1.0k Views 4 Watching
    • syburnS Offline
      syburn
      i was looking for transparent clear material (perspex / acrylic) with none of the standard green or grey tint. They will not let me change colour in the material editor. Anybody know how to solve this conundrum?
      Also how do u all make polished stainless steel look abit like s/s??
        remus
        you need to make sure youve applied the amterial to a surface before you try and change it, if youve already done that, then im not sure what could eb causing the problem ๐Ÿ˜’
          RonanR
          As remus said, you've got to
          a. apply the material you want
          b. click edit on the Material window
          c. change the opacity.
          I use perspex all the time in my drawings, and either use Transluscent glass blue or grey with opacity down to between 5 and 15 depending on the thickness of Perspex (acrylic) used.
          Hope this helps.
          %(#BF00FF)[Please keep signatures minimal.
          Oh, and ditch incandescent light bulbs.]
            It's been said...
            You can't edit the SUp base materials in the browser.
            BUT you CAN edit the model's materials (see 'little house' button in browser).
            IF you have made a material in a model that you want to be accessible to any future models - via the 'base set' - then do a "Save_As" of this new material (in the model's material browser window select it and right-click to get a context menu...). Put it with only similar materials in your Materials folder structure... New models get access to it...
