    Missing 2D Exporters? [fixed]
    12 Posts 8 Posters 3.3k Views 8 Watching
      Mr S
      Just went to render a small JPEG file.
      And an error dialog box came up informing me that:
      "It appears that you are missing some 2D graphic exporters. Please check your SketchUp installation"
      After dismissing this warning I am taken to the normal export dialog.
      Looking at the file type drop down list, I can export to:
      pdf
      eps
      bmp
      jpg
      tif
      png
      epx
      I have done a fresh install of SketchUp v6.4.112 (I already had this installed)and still get this error.
      Any ideas guys?
      Regards
      Mr S
        Charlie__V
        Mr S,
        .dwg
        .dxf
        are missinf from your drop down.
        Sorry I do not have a solution
        C
        • Alan FraserA Offline
          Alan Fraser
          Can you still export 3D dxf and dwg files?.....given that the two 2D formats that seem to have disappeared are both CAD.
          3D Figures
            richcat
            Mr S
            Have a look a this thread it should help. http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=4203
            Richcat
              Jeremy Nicholls
              I posted about very similar 3D export difficulties:
              404 Not Found
              (www.sketchucation.com)
              No solution has been given yet. There is another recent post about PDF problems.
              It would seem these are indicative of some deeper problem. I did flag my thread directly to the Brad, but havn't received a response as yet.
              Jeremy
              (too many 'problems' - sorry)
              • AnssiA Offline
                Anssi
                Have you tried to download SU again and do a "repair" install?
                Anssi
                  Jeremy Nicholls
                  I tried a repair - no difference. I uninstalled SU and downloaded Pro6 again from Google SU and installed from scratch. No difference. See my thread.
                  I think this needs a response from Google immediately.
                  Jeremy
                    Moved to the bug reports forum.
                    I'll try to draw some attention of the SU Team on this.
                      Mr S
                      Yes, I had downloaded the SketchUp FREE update instead of the PRO version.
                      Just downloaded and installed the correct version and everything appears to be back to normal. Thanks for your help again guys.
                      Regards
                      Mr S
                        Then where should I (re)move the topic?
                        πŸ˜„
                        well, leave it here. Others may learn from it...
                        • Paul RussamP Offline
                          Paul Russam
                          Move it from bugs (as its not one) and amend the title with '(Fixed)'
                          Paul Russam
                          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                            Good point!
                            πŸ˜‰
