    Problems with the new computer.
    46 Posts 9 Posters 4.2k Views 9 Watching
    • boofredlayB Offline
      boofredlay
      Honestly I feel like I am reading another language... how do I check this?
      • soloS Offline
        If all else fails, try this: http://downloads.guru3d.com/download.php?det=1852
        171.23 forceware drivers.
          boofredlay
          That driver is newer than the one listed on NVIDIA's site. Is it safe to install? Why would NVIDIA not have it on their site but have it on the one you listed?
          Curious.
          @solo said:
          I see you have one GPU, are you certain that the SLI option is NOT selected in the bios setup? and on Motherboard you have a chip that you flip when you have two GPU's to enable SLI, make sure it's not on the dual GPU side.
          Again, I have no idea how to check this.
          • soloS Offline
            Without knowing your Bios navigation it's hard to explain, I hunted for a screenshot for your Bios without luck.
            Lets try this:
            When you navigate your bios you get many options, there is one that you can select first mode of graphics which should have PCI-e selected, then there should be a selection for the GPU in dual or single mode, make sure single is selected.
            As far as Forceware drivers are concerned, they are as they say Forceware and not official drivers (thats why they have disclaimers, it's a gamers tool to squeeze our as much juice they can get by using breakneck drivers), they also use the new DirectX 10 (not sure there will be any advantage for you as DX 9 is all you require for openGL requirements, more of a gamers thing for the latest game support)
              boofredlay
              Thanks, where do I look for the Bios? 😳
              @solo said:
              In PS have you set up the performance settings in preferences?
              I cannot find the performance settings in Photoshop. When i go into preferences I get the following:
              File Handling
              Display & Cursors
              Transparency & Gamut
              Units & Rulers
              Guides, Grids, & Slices
              Plug In's & Scratch Discs
              Memory & Image cache
              I looked through them all and could not find anything resembling performance settings.
              Again Photoshop 7.
              Pete, I really appreciate your help.
              • soloS Offline
                http://img165.imageshack.us/my.php?image=pssd8.jpg
                This is all I could find, I do NOT use Photoshop (do not even have it loaded ) I am a Paintshop pro user.
                Maybe a PS user can jump in at this point.
                The bios...If you have never fiddled with it, then rather not touch it as you can screw your rig up if you have no idea (like playing with Reg edit)
                  boofredlay
                  Thanks Pete, this must be from a newer version of Photoshop. There have been 3 or 4 since version 7.
                  And I will definately not touch the BIOS. I fear screwing something like that up.
                  Well as it stands now the only problems I seem to have are the flickering in Photoshop (only on color images) and the wheel mouse button... I can orbit just fine until I wheel out or in more than once. Then I have to click the wheel button twice before I can orbit. Then it will orbit fine again. Hmmm.
                  • soloS Offline
                    This may sound stupid as it really is, but I too use a MS optical usb scroll mouse, I had issues with it conflicting with my 3d connexion device and also with MAX (scrolling stuttering) I uninstalled the driver and restarted rig and just plugged it in as a generic scroll mouse and never had an issue again, however that was due to a Vista conflict. It may work for you too, nothing lost if it does not as the mouse will work regardless.
                    • soloS Offline
                      try inserting a PS2 mouse if you have one and see if it helps.
                        boofredlay
                        The only other mouse in the house is the same model on the old computer. I switched them out and got the same result.
                        I will try uninstalling the mouse driver.
                          boofredlay
                          Well, I did not even need to reboot the system. As soon as I removed the Intellipoint 6.1 software the problem was fixed. I can wheel zoom many times and only have to clik once to orbit.
                          😍 Pete you are a lifesaver. 😍
                          I am going to have to go to work now. I will check in when I get there to see if anybody has more help with the Photoshop flickering.
                          Thank you.
                          • soloS Offline
                            Only a pleasure, glad you can get to work now.
                            many Form Font subscribers need you.
                              boofredlay
                              Aww shucks. 😳
                              Well what do you know, I decided to check Photoshop one last time and it seems the flickering has stopped.
                              It seems that my little mouse was a bit of a troublemaker...
                              Pete, the next time I am visiting my mother in Kerrville I will stop through and buy you a steak. πŸ˜„
                              • soloS Offline
                                Sounds good to me, I will be in Huntsville visiting in-laws and some outlaws this summer, maybe we can get a beer together.
                                • FrederikF Offline
                                  Frederik
                                  This has been almost like a movie... I would never have guessed that it was the mouse...
                                  Glad it had a happy ending... πŸ˜„
                                  I sure felt with you, Eric, when you said...
                                  Cheers
                                  Kim Frederik
                                  • tbdT Offline
                                    tbd
                                    ... be sure to tune in next week for the episode 'TBD and his almost same setup'
                                    Boofredlay: we are waiting for the "behind the scene" clip (= how is the new computer flying)
                                    http://plugins.ro
                                    • Alan FraserA Offline
                                      Alan Fraser
                                      We should rename this thread Mouse Tale.
                                      3D Figures
                                        boofredlay
                                        Sounds great, although I will be drinking tea. I gave up the booze almost 4 years ago and have not looked back. Although over the last couple days a cold one would have settled my nerves 😎
                                        Frederik, I am glad my pain has amused you πŸ˜† Just kidding.
                                        Alan, I think I can find a few good names for that mouse, or at least the software that came with it.
                                        Kind of ironic don't you think... I killed an entire mouse colony that settled into my garage this fall. πŸ˜•
                                        About nine mice in all.
                                          tomsdesk
                                          Ah...the dread intellipoint software bug again: you got off easy, my friend!
                                          2.5D Trees & Shrubs!
                                            boofredlay
                                            You warned me didn't you.
                                            Edit: Although as soon as I removed the software I left home and am now at work. I wonder if I will find any more glitches tonight.
                                            • 2 / 3
