    Problems with the new computer.
    46 Posts 9 Posters 6.2k Views 9 Watching
    • soloS
      I see you have one GPU, are you certain that the SLI option is NOT selected in the bios setup? and on Motherboard you have a chip that you flip when you have two GPU's to enable SLI, make sure it's not on the dual GPU side.
      • boofredlayB
        boofredlay
        Honestly I feel like I am reading another language... how do I check this?
        • soloS
          If all else fails, try this: http://downloads.guru3d.com/download.php?det=1852
          171.23 forceware drivers.
          • boofredlayB
            boofredlay
            That driver is newer than the one listed on NVIDIA's site. Is it safe to install? Why would NVIDIA not have it on their site but have it on the one you listed?
            Curious.
            Again, I have no idea how to check this.
            • soloS
              Without knowing your Bios navigation it's hard to explain, I hunted for a screenshot for your Bios without luck.
              Lets try this:
              When you navigate your bios you get many options, there is one that you can select first mode of graphics which should have PCI-e selected, then there should be a selection for the GPU in dual or single mode, make sure single is selected.
              As far as Forceware drivers are concerned, they are as they say Forceware and not official drivers (thats why they have disclaimers, it's a gamers tool to squeeze our as much juice they can get by using breakneck drivers), they also use the new DirectX 10 (not sure there will be any advantage for you as DX 9 is all you require for openGL requirements, more of a gamers thing for the latest game support)
              • boofredlayB
                boofredlay
                Thanks, where do I look for the Bios? 😳
                @solo said:
                In PS have you set up the performance settings in preferences?
                I cannot find the performance settings in Photoshop. When i go into preferences I get the following:
                File Handling
                Display & Cursors
                Transparency & Gamut
                Units & Rulers
                Guides, Grids, & Slices
                Plug In's & Scratch Discs
                Memory & Image cache
                I looked through them all and could not find anything resembling performance settings.
                Again Photoshop 7.
                Pete, I really appreciate your help.
                • soloS
                  http://img165.imageshack.us/my.php?image=pssd8.jpg
                  This is all I could find, I do NOT use Photoshop (do not even have it loaded ) I am a Paintshop pro user.
                  Maybe a PS user can jump in at this point.
                  The bios...If you have never fiddled with it, then rather not touch it as you can screw your rig up if you have no idea (like playing with Reg edit)
                  • boofredlayB
                    boofredlay
                    Thanks Pete, this must be from a newer version of Photoshop. There have been 3 or 4 since version 7.
                    And I will definately not touch the BIOS. I fear screwing something like that up.
                    Well as it stands now the only problems I seem to have are the flickering in Photoshop (only on color images) and the wheel mouse button... I can orbit just fine until I wheel out or in more than once. Then I have to click the wheel button twice before I can orbit. Then it will orbit fine again. Hmmm.
                    • soloS
                      This may sound stupid as it really is, but I too use a MS optical usb scroll mouse, I had issues with it conflicting with my 3d connexion device and also with MAX (scrolling stuttering) I uninstalled the driver and restarted rig and just plugged it in as a generic scroll mouse and never had an issue again, however that was due to a Vista conflict. It may work for you too, nothing lost if it does not as the mouse will work regardless.
                      • soloS
                        try inserting a PS2 mouse if you have one and see if it helps.
                        • boofredlayB
                          boofredlay
                          The only other mouse in the house is the same model on the old computer. I switched them out and got the same result.
                          I will try uninstalling the mouse driver.
                          • boofredlayB
                            boofredlay
                            Well, I did not even need to reboot the system. As soon as I removed the Intellipoint 6.1 software the problem was fixed. I can wheel zoom many times and only have to clik once to orbit.
                            😍 Pete you are a lifesaver. 😍
                            I am going to have to go to work now. I will check in when I get there to see if anybody has more help with the Photoshop flickering.
                            Thank you.
                            • soloS
                              Only a pleasure, glad you can get to work now.
                              many Form Font subscribers need you.
                              • boofredlayB
                                boofredlay
                                Aww shucks. 😳
                                Well what do you know, I decided to check Photoshop one last time and it seems the flickering has stopped.
                                It seems that my little mouse was a bit of a troublemaker...
                                Pete, the next time I am visiting my mother in Kerrville I will stop through and buy you a steak. πŸ˜„
                                • soloS
                                  Sounds good to me, I will be in Huntsville visiting in-laws and some outlaws this summer, maybe we can get a beer together.
                                  • FrederikF
                                    Frederik
                                    This has been almost like a movie... I would never have guessed that it was the mouse...
                                    Glad it had a happy ending... πŸ˜„
                                    I sure felt with you, Eric, when you said...
                                    Cheers
                                    Kim Frederik
                                    • tbdT
                                      tbd
                                      ... be sure to tune in next week for the episode 'TBD and his almost same setup'
                                      Boofredlay: we are waiting for the "behind the scene" clip (= how is the new computer flying)
                                      http://plugins.ro
                                      • Alan FraserA
                                        Alan Fraser
                                        We should rename this thread Mouse Tale.
                                        3D Figures
                                        • boofredlayB
                                          boofredlay
                                          Sounds great, although I will be drinking tea. I gave up the booze almost 4 years ago and have not looked back. Although over the last couple days a cold one would have settled my nerves 😎
                                          Frederik, I am glad my pain has amused you πŸ˜† Just kidding.
                                          Alan, I think I can find a few good names for that mouse, or at least the software that came with it.
                                          Kind of ironic don't you think... I killed an entire mouse colony that settled into my garage this fall. πŸ˜•
                                          About nine mice in all.
                                          • T
                                            tomsdesk
                                            Ah...the dread intellipoint software bug again: you got off easy, my friend!
                                            2.5D Trees & Shrubs!
                                            • 2 / 3
