    IMPORTING FROM AUTOCAD
    25 Posts 11 Posters 7.9k Views 11 Watching
    • AnssiA
      Anssi
      Hi all,
      AutoLisp and other nice full AutoCad features are available to AutoCad LT in an affordable package from the Australian software company DRCauto http://www.drcauto.com/
      I haven't tested their most recent offers, but an earlier version of their Toolkit worked flawlessly. It's also the basis of many third party add-ons to LT.
      A DWG with irritating lines in 3D can be flattened easily with SU too: Select the Plan view, turn off Perspective (select Parallel Perspective), export a 2D image as DWG to full scale, and reimport.
      Anssi
      • G
        guite
        WOW! Ansii, that's way cool!!! That's a nice and new idea, fresher than this morning's milk delivery!!
        Guite
        PS: Not that we get stale milk, sorry your quick wit guys 😄.
        • T
          tomsdesk
          I'll double the WOW! and thanks Anssi...neat trick!
          Also, much abliged for the link to DRC...I'm thinking it may be time to update my autocad and this time it will have to be LT: $$$
          2.5D Trees & Shrubs!
          • P
            peterbnilsson
            That's a great time saver Anssi, thanks for the tip. I can't believe that hasn't occurred to me before. I'd heard of the drcauto software before but haven't ever ponied up for it. It would be nice to have the functions back that I was so used to, I'll have to pitch this idea to my boss.
              dylan
              Great tip Annsi and I wish I knew this last week, ive been fighting with the worst cad drawing ever. Parts of it being in 3d for no apparant reason is only part of it!
              http://dmdarchitecture.co.uk/
              • B
                Bayer
                Really appreciate all the help everyone, like I said I am just getting started with SU and will try out these solutions. I will return to let you know how it went.
                Enjoy
                • B
                  Bayer
                  Annsi -
                  I have tried your idea and it is not working, It is my belief that the solution you gave me dealt with the pro version of sketchup, I cannot export the sketchup drawing as a dwg and then reimport it. Let me know what you think, and if purchasing the lisp is a good solution. My other thought and i have not tried it, is to create a scaled pdf import it into sketchup and then scale the import accordingly. Thanks Again.
                  • AnssiA
                    Anssi
                    Bayer,
                    The trick is an old one but yes, it works only with the Pro version, as the Free one doesn't have DWG export. Of course, if you have access to AutoCad, the flattening can be done there. The Flatten command is part of the Express tools that is included in the AutoCad distribution, you don't have to purchase it separately. It's command line only, so it is not included in menus. Free lisp versions of the command can be found from many locations on the Internet too, if your version happens to miss the command.
                    Anssi
                    • B
                      Bayer
                      Annsi - correct me if I am wrong, but I do not think AutoCad 2008 LT has express tools, hence I cannot use flatten as an option. I am sorry if this is inconvenience but I am new to both Autocad 2008lt and the free verson of sketchup 6 and still trying to understand them both. Please let me know what you would do, and if it will require me to download or pruchase any additional tools, left out in the 08 lt version. Thanks agaun for all your time and consideration.
                      Bayer
                      • AnssiA
                        Anssi
                        Bayer
                        From AutoCad or AutoCad LT you can also use the DXB method:
                        • configure a DXB plotter
                        • plot to DXB file
                        • use the DXBIN command to import the DXB file
                        • scale the import and save as DWG
                        See also:
                        http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2876115&linkID=9240617
                        Anssi
                        • P
                          PRSS
                          Regarding using Lisp in LT, there is a great software at a very
                          low price. It is LT Extender.
                          Please look at this: http://www.lt-extender.com/LT-Extender/englisch/default.htm
                          With best regards
                          PRSS
                          • 2 / 2
