    In Development: Subdivide and Smooth
    262 Posts 65 Posters 48.4k Views 65 Watching
    • boofredlayB Offline
      boofredlay
      @whaat said:
      I don't understand this workflow. How do you create your high-poly models in the first place? If you are creating them with software other than SU, it only makes sense to use the same software to reduce the poly-count prior to bringing the model into SU. I am sure Max and Blender can both do this.
      To me, the logical workflow would be to model everything in SU as low-poly. Now you have your low-poly model. Next add one level of subdivision. Now you have your medium detail model. Add one more level of subdivision and you have your high-poly model.
      Of course, the option to reduce poly-count would be useful as well, but it seems rare that someone would want to reduce the polys of a model that was originally made in SU.
      Maybe you could give a more detailed example of your workflow that would require such as feature.
      For me, and the reason I posted This Thread, I would like to be able to reduce the polygon count for something I created with Soap Skin or even the sandbox tools. As I don't use any other modeling program (well I use Revit but for a whole different thing) I would like to see this ability.
      Maybe it would be as simple as adding a + or - value when running the script. If that makes sense.
      Thanks again for this and I await it being public, even if it won't work both ways 😄
      • W Offline
        Whaat
        i'd love for someone to show me the way on this.. especially the 30 sec clean method that whaat is talking about..
        thanks for any input,
        jeff
        Hey Jeff,
        It looks like the type of work that you are doing requires a fair bit of precision with respect to exact radii and tangents, etc.
        This plugin is not designed for precision. It is more useful for conceptual or organic stuff. I think you might find the plugin useful for quickly playing around with concepts. You can model your surface in very low-poly without using soap-skin and then use the plugin to smooth it out.
        This is the method I am referring to. I modeled the surface in very little time (ok.. a bit longer than 30 seconds... 😉 ). You can see how the surface flows seamlessly after applying the plugin.
        However,
        • jeff hammondJ Offline
          wow, you got That from That.. great..
          most of the stuff i do is wooden structure but i also do some concrete work.. i try to use each medium to its advantage which in turn leads to different style designs.. your plugin will be excellent for the concrete stuff where organic shapes are much more manageable...
          do you have an e.t.a. by any chance?
          thanks
          fwiw, i was able to fix that bad spot in the first picture i posted here.. i managed to ditch 2 of the three soap skins and the rest of the model is moving along nicely now..
            kwistenbiebel
            Hi Whaat,
            As you asked in the Indigo forum, I upload the 'naked running man' SU model that was made in 'Make Human' so you can test it with your S'nd S project.
            (The complete scene was way too big to upload).
            Cheers,
            Kwistenbiebel
            loper2.zip
            • MarianM Offline
              Marian
              I can see this plugin being very useful to me helping with my car and ship modelling.
              Is this going to be a free plugin or commercial?
              • N Offline
                notareal
                @fletch said:
                wowwwww Whaat... you are incredible! 😲
                can it reduce the polygon count of a hi-poly mesh (work in reverse) too?
                I think this would be good feature too, if do not consider it too difficult to implement.
                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                • N Offline
                  notareal
                  Some free models, for example 3d scanned ones, do have really high poly-count. I can imagine using some of those in SU, but after some scale down.
                  • N Offline
                    notareal
                    What about components made of 1/4 parts, like this glass. Object has parts that are not wanted to subdivide and also open edges of sub-components needs to be left without subdivision. Glass_sub.jpg
                    Glass_A1.skp
                    • W Offline
                      Whaat
                      Since so many people are asking for this poly-reduction feature 😲 , I will try to create a plugin to do this. However, this will not be until after the subdivision plugin is released.
                      I have no idea when I will release it. There's LOTS of work left before I would be comfortable releasing it.
                      • PixeroP Offline
                        Pixero
                        What about a "non destructive" subdivision?
                        Meaning: the possibility to go back to a lower subdivision for further modelling.
                        Then go back to the higher subdivision for rendering.
                          boofredlay
                          Thank you. 👍
                          • F Offline
                            Fletch
                            oh no... sub-object modeling in SU like in VIZ... 😲 ... too complex for my little brain to handle...
                            just kidding! I would like that too, but let's let him get this thing done first, shall we?! We don't want to sound ungrateful... 😄
                            Fletch
                            Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                            • W Offline
                              Whaat
                              Here's another preview...
                              http://www.members.shaw.ca/marshallamp20/preview.gif
                                Jon
                                This is astonishing! Maybe I don't have to learn Blender for my organic modeling after all!
                                Jon
                                KT Team member
                                • soloS Offline
                                  Let me at that....please!!!
                                  I am liking what I see....need a beta tester? 😆
                                    remus
                                    wow! looking good whaat, being able to see what your doing before you do it is very cool, i wouldnt mind joining solo on the beta testing 😄
                                    • PixeroP Offline
                                      Pixero
                                      YEEEEES! 😍
                                      Look very promising. Can't wait.
                                      • W Offline
                                        wikii
                                        What?!!!!!!!!!!
                                        So great!
                                          linea
                                          I second that.
                                            Gjenio
                                            I second that.
                                            Me too
                                            • 13
                                            • 14
                                            • 3 / 14
