    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Plugin] Set North in Free version
    22 Posts 11 Posters 26.8k Views 11 Watching
    • Didier BurD Offline
      Didier Bur
      Am I stupid or missing something ?
      There's no other way to set the North in GS6_free than loading Google Earth, select the town, capture the view with GE plugin to set Lat/lon coordinates, etc, etc.
      So here is a little tool to do it without Google Earth, simply enter the north angle relative to the green axis, clockwise. The script will temporarily display the current North if not displayed.
      The command is in the "View" menu.
      Get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=gs6_north
      This is the OLD version !
      Get the latest RBZ from the PluginStore...
      DB
        And what about the localisation?
        Is it automatic from the time zone of the computer system or it's not possible on the SU6 free?
          Didier Bur
          Pilou,
          Pas d'onglet "Emplacement" dans GS6 Free... πŸ‘Ž
          DB
            So it's always same shadows with the ruby North?
              Jim
              I need to advertise more.
              Plugin: Model Location
              * This plug-in was made for SketchUp version 6 Free because it lacked the dialog (which Pro had) to change these settings. This has become ...
              (sketchuptips.blogspot.com)
              • F Offline
                Fletch
                Yes you do, Jim, you rock!
                Thanks to you too, Didier! (for like the 100th time...) What would we do without you?
                Fletch
                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                • F Offline
                  Fletch
                  Didier, your tool for setting custom north angle still works perfectly in SU8 free.
                  Fletch
                    Didier Bur
                    πŸŽ‰ 😍
                    DB
                    • irwanwrI Offline
                      irwanwr
                      does it still work with SketchUp 8?
                      • andybotA Offline
                        andybot
                        @irwanwr - did you see this? This one works great and does work in SU8 free
                          This doesn't really give much helpful information back to the developer. What "doesn't work"? Error message? Unexpected results from usage? Please provide more information when reporting problems - it's is impossible for us ( developers ) to guess what the issue is - could be any number of reasons.
                          • irwanwrI Offline
                            irwanwr
                            πŸ˜† sorry people. i was wondering.
                            since in the SketchUp 8 Free version it seems that the "set north angle" doesn't work.
                            unless i missed something there.
                            that's why i've been wandering around the Plugin Index. looking for something to replace that Pro feature for the Free version.
                            it's quite tiring now, to set latitude and longitude manually every time and then realising that you need to rotate the whole model to adjust the position for the correct illustration.
                            any info or hint? thank you.
                            [ed] thank you, andy. πŸ‘ no, i didn't see that. it's a link with not much of description what it was πŸ˜› .. but, that's look like it. funny though i visited Jim's site for his cline before πŸ˜„
                            erm... but Jim said there;
                            • This plug-in was made for SketchUp version 6 Free because it lacked the dialog (which Pro had) to change these settings. This has become obsolete since SU 7.
                            what's that supposed to mean? i am planning to use only SU 8 now.
                              I do not know about Didier's plugin (never used) but yes, Jim's plugin works in SU 8 free, too.
                              • irwanwrI Offline
                                irwanwr
                                now, i understand what was that supposed to mean
                                Jim should've make that Model Location instead πŸ˜†
                                thank you andybot, Thomas, and Csaba πŸ˜„
                                • andybotA Offline
                                  andybot
                                  In SU7 free, you could set the north direction (like the plugin does,) which Google then took away in the SU8 free version... it's only available in SU8 pro
                                  • irwanwrI Offline
                                    irwanwr
                                    hi everyone,
                                    i am back. Didier's and Jim's plugin both works well in SketchUp 8! πŸ˜„
                                    with Didier's "Set North" i can change the north angle orientation. and
                                    with Jim's "Model Location" i got the full feature of geolocation
                                    sorry for rushing around and replying without even checking what others have to say up there. especially Jim's and Fletch's post.
                                    you people couldn't stop to amaze me yet with this forum πŸ˜„
                                    i regret those days -erm.. years- without SketchUp 6 and this forum πŸ˜›
                                    SketchUp 8.0.4811 currently.
                                      Didier has agreed that I might update some of his scripts in the PluginStore.
                                      This is an oldie but it now compatible with all SUp versions [useful in Free/Make where there is no Geolocation...] http://sketchucation.com/pluginstore?pln=gs6_north
                                        ssw
                                        I am using SU 8 free. I am trying to install a plugin that allows me to change north.
                                        Tried Jim's plugin (http://sketchuptips.blogspot.com/2008/01/plugin-model-location.html), but it requires inputbox.rb which is not available on jim's site.
                                        I get a message "works on free version only" when I tried Didier's plugin
                                        Any help greatly appreciated
                                          I you install the latest version of Didier's tool it does NOT give a message box with that message !
                                          Please get the RBZ that contains the latest version from the Download link button in the recent post [or even the first post] - it's in the SCF PluginStore !
                                          The old RB file in the first post IS out of date [as it says]...
                                          The new version works in all SketchUp versions...
                                            robinpecha
                                            Hi, great tool, but...
                                            Im using last version available in PlayOnLinux tool which is Google Sketchup 8.0.15158 free.
                                            After installation plugin works.
                                            But from first restart of application it allways show:
                                            "Error Loading File gs6_north.rb
                                            undefined method `file_loaded?' for DBUR:Module"
                                            I must erase plugin manualy. And each time I wont set north, Im installing plugin, setting and then erasing.
