    Scaling uniformly using VCB
    16 Posts 7 Posters 3.9k Views 7 Watching
    • H Offline
      Howard leslie
      Philip,
      I've created a tutorial for you:
      See
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=22&t=3439
      2 Methods
      Hope this helps
      Howard L'
      • Jean LemireJ Offline
        Jean Lemire
        Hi Philip, hi folks.
        See attached SU file for ideas.
        I used one of the side handles with the SHIFT key and the ALT key together to get a scale about the center AND a uniform scale along two axis at once.
        That is on a Mac. On a PC you would use SHIFT and CTRL.
        Tapered column.skp
        • philemP Offline
          philem
          Hi Jean,
          Thank you for the tutorial, but I must be missing something,
          I made a copy of the profile on sheet one, then followed your directions,
          But (and this is where I am missing something) Every time I let go of the Shift and CTRL keys (PC) tp type in the dimension, the red scale handle that is on the center disappears to the outside and when I type in the figures the model scales only on one axis.
          What am I doing wrong?
          thanks
          Philip
          Just do it, it might be fun.
            Philip,
            Just keep the Shift+Ctrl buttons pressed when starting the scale operation then release everything, type and hit enter.
            Like with most of the actions in SU, you can enter the values into the VCB immediately after the operation (in this case scaling) and not only during the operation.
            • philemP Offline
              philem
              @gaieus said:
              Philip,
              Thanks Gaieus
              It started to make sense, and it also worked, thanks for taking the time 😄
              Philip
                kwistenbiebel
                Sorry to dig up this old one...but is it possible to do a 'Copy+ scale uniform around center'?
                Basically I need to offset an object to the centerpoint while scaling the coby down.
                A box in a box so to speak....(in my case no box but car windows I need to make double glazed)
                Is that possible?
                  No, with the scale tool you cannot perform copying (like the linear and radial arrays with the Ctrl^Move or Rotate tools).
                  I know what you mean because I have played around with boat hulls and when I wanted to make thickness to the tediously created mesh, I obviously didn't want to stitch all those beziers together again.
                  My workaround in this case usually is that I make a Ctrl+Move copy somewhere out, scale the new copy (carefully choosing which direction, about opposite point or center etc. I scale it) and then move it back.
                  Now however there is this great script "Joint Push Pull" by Fredo that can help you (although I succeeded to screw it up with a hull but that was most probably my fault 😒 )
                  I have made this shield (and also its edges even thicker) with this script. On that path I could not have used the Follow me tool so finely. I guess if your glass is not too curvy, it must work pretty well.
                    GreyHead
                    You can do Copy, then Paste in Place and scale the new copy - I think that has the same effect.
                    Bob
                      True but make sure you group the geometry prior to it since otherwise it will simply merge with the original.
                        kwistenbiebel
                        Thanks Greyhead and Gaeius for the tips.
                        the simple copy and 'paste in place method' worked like a charm. 😄
