    Modeling curve scuplture
    17 Posts 10 Posters 1.9k Views 10 Watching
      lapx
      How would you model something like this accurately?
      • jeff hammondJ Offline
        here's my Super rough first try... i went around the thing too many times... 2nd try should be easier and i'll try smoothing out the kinks..
        knot1.skp
          remus
          Id try and do it by drawing and connecting arcs, you could draw the arcs on a plane so you could get the angles and stuff a bit more accurate, otherm than that im not sure. Quite a challenge.
          p.s. use the arcs and stuff for a follow me path.
          • soloS Offline
            I was not even going to attempt that complicated shape, I did however do a little spiral and render it as glass.
            http://img254.imageshack.us/img254/7899/glassspira700lul9.jpg
              alpro
              solo, spill the beans already, are you beta testing v2.0? 😆
              Mike
                GreyHead
                The shape is a mathematical curve called a trefoil. I created one using using knotplot and shipped it into Sketchup.
                In the render I forgot to smooth the skippy so it went a bit jazzy!
                Bob
                The trefoil skippy
                  remus
                  Nice one bob, far cleaner than anythign that could easily be produced in SU! cheers for sharing it.
                  edit: i was going to try and do a render of this in podium, but podium is struggling slightly (a lot!) with it.
                  • FrederikF Offline
                    Frederik
                    It looks really good, but it lacks caustics... 😉
                    Cheers
                    Kim Frederik
                    • soloS Offline
                      Thanks Bob, nice find.
                      http://img143.imageshack.us/img143/444/knotytb0.jpg
                      With caustics
                        ha.. man, i was just starting to get my head around what's actually going on with this shape and was about to start trying out the proper curves... then i open up this thread... i'm throwing in the towel after seeing knotplot..
                        check out this project..
                        http://ingallian.design.uqam.ca/goo/ReV/ReV00.htm
                        knot2.skp
                          a non transparent version..
                            kwistenbiebel
                            Solo,
                            Is that Vue you are rendering with?
                            By the way, I wouldn't have a clue how to model a doodle like that in sketchup..😉
                            • N Offline
                              notareal
                              I am great fan of mathematical shapes. Nice model, did made a subdivision in KT. Take a look on k3dsurf, nice program for creation of mathematical models.
                              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                lapx
                                This is an amazing response, Thanks Bob! I'll try my rendering in K when I get a break in action and post my attempt. There is so much useful knowledge generated here ☀
                                  lapx
                                  My attempt rendered with KerkyT.
                                  • ely862meE Offline
                                    ely862me
                                    new things
                                    Elisei (sketchupper)
                                    Come and See EliseiDesign
                                      tried one with cheetah.. just using the trial version for now (everything works normal and it doesn't expire - you just can't save anything.. this is a screen shot)..
