    How can I model a twisting / looping arrow?
    19 Posts 6 Posters 2.8k Views 6 Watching
      remus
      was it just a case of move a copy up, rotate it, stitch between the two, make it acomponent, copy up rotate, etc. ?
      • Alan FraserA
        Alan Fraser
        I just made a box then rotated the top surface by 5 degrees, using autofold. I then removed the top and bottom surfaces and copied it upwards, snapping two appropriate corners, then rotated into position....again inferencing a snap into position.
        It doesn't take very long at all, because you can then copy two boxes then 4, then 8 etc, before smoothing the sides.
        3D Figures
          Ampa
          Thanks Alan for the idea.
          I tried your method: it is indeed pretty simple and no slower than fiddling with the rubies.
          When I render the model (and indeed it is visible in native SketchUp) the bottom 6 segments are not as smooth as the rest.
          Why is this? Is there anything that I can do about it?
          As before, your help is appreciated. Thanks for taking the time to share your knowledge.
          Mine on the left, Alan's on the right.
            remus
            If you push pull the rectangle in smaller increments, it should minimise the effect, altohguh i cant think of a way of completely eliminating it.
            • Alan FraserA
              Alan Fraser
              If you mean by "not as smooth", the fact that you can see some triangulation shadows at the base, then that's just the way that SU handles shadows...they are vector-based and none too subtle. You can see this by moving the time slider...they will run up and down the column.
              Flipping the triangulation lines won't do any good either...it'll just shade the other way around.
              As Remus says, you can alleviate it with smaller increments...like not rotating as much as 5 degrees, but I doubt you'll get rid of it altogether.
              3D Figures
              • jeff hammondJ
                you could mess around with the soap skin bubble and drawhelix... the triangulation will still be present but you can get it pretty small..
                twisted.skp.zip
                • jeff hammondJ
                  similar technique for the loop...
                    Ampa
                    Thanks for the lates round of ideas.
                    Alan / Remus: Yep smaller increments seems to help. I have a nice smooth barrel roll, and loop the loop πŸ˜„
                    Jeff: Soap Skin is an interesting idea, I'll toy with that too πŸ˜„
                    Next issue: Both examples so far use rotation about 1 axis, and in the case of the loop a displacement along a second axis. But I'd also like to try an arrow with rotation about two axies, such as a loop with a roll.
                    I've tried this a couple of times using the rectangle > push-pull > rotate > copy > rotate into place technique BUT I can't seem to make the copy match perfectly with the original. I am sure it is possible. I am obviously rotating in the wrong order, or about the wrong point. Perhaps someone can show me the way?
                    Thanks again, Ampa.
                    Twist around Y (1 degree per segment)
                    Loop-the-Loop (Rotation about X with lateral displacement)
                    • jeff hammondJ
                      i did the corkscrew in a similar manner as the twist.. the only difference is the point at which the face is rotated around.. i used big segments with 15 deg rotation but i'm sure you can spend some more time with it and get the results you're getting with the other shapes..
                      (note - i had to use the scale tool to flip the thing around once i was finished in order to get the orientation right.. i think i did green axis and blue axis at -1)
                      corkscrew.skp
                      • jeff hammondJ
                        for anyone curious...
                        just messing around with a new screen capture app and that corkscrew posted above... those mouse click things are kind of weird i guess but i can turn them off in the future.. i think it'd be cool if the keyboard keys would show up so the shortcuts are visible.. you can still see which tools are being used by looking at the toolbox.. i shrunk the window so the VCB is visible..
                        corkscrew_su.mov.zip
                          Ampa
                          Jeff: Your corkscrew is great, the video really shows just how quick it should be. I agree with you that the 'red shockwave' click animation is a bit over the top, though it does make it very clear when yu have clicked!
                          I think the idea that I've not yet addopted is adding dummy geometry to act as a rotation point / guide for my model.
                          Here is a render of a similar corkscrew (not as pretty as yours though, too compact!)
                          Thanks for taking the time out, to help a relative noob!
                          Corkscrew (5 degree twist per segment - not quite smooth)
