    Marin Mountain Bike (WIP)
    62 Posts 27 Posters 12.7k Views 27 Watching
      rsw
      DT spokes on one side of hub now attached to DT E540, double wall rim:-
      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_wheel1.jpg
      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_wheel2.jpg
      Close up of rim (tyre is a placeholder for now)
      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_wheel3.jpg
      @will03 said:
      you're going to need one monster of a machine, when that model is all put together! good luck my friend!
      I'm planning on using simple placeholder components to reduce the size of the working model
      Richard
      • boofredlayB Offline
        boofredlay
        Holy smokes, that is awesome detail.
          todd burch
          Wow! The only thing missing is the tassles hanging from the grips! Chicks dig tassles. ๐Ÿ˜†
          Todd
            rsw
            More detail added to wheel now
            Almost complete front wheel (click for larger image):
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_front wheel 1.jpg
            Side view:
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_front wheel 3.jpg
            Section through tyre:
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_front wheel 2.jpg
            quick render in KT:
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_front wheel 4.jpg
            All that is missing from this front wheel is the valve. After that, next to model will be the front forks.
            Richard
            • U Offline
              Unknown Target
              Wow, that's awesome! Mind if I ask how you placed the tire nubs so precisely and regularly all around the wheel?
                cheffey
                That is awesome, great work in progess shots.
                I would also like to know how to place the knobbies on tires like that, is there a tutorial around here?
                Coming along nicely though. ๐Ÿ˜Ž
                BROS RลŒMAN BRร„UN
                  rsw
                  Similar method to this here, although a little bit more complicated, due to the curved tyre profile. If I have time I might explain it in more detail later.
                  Richard
                    rsw
                    Not really had much time to work on this recently, but here's part of the frame at the moment:
                    Cross Section:
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame3.jpg
                    Close up of logo:
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame2.jpg
                    Close up of logo:
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame4.jpg
                    Quick render:
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame5.jpg
                    Richard
                      rsw
                      another quick update to this...
                      Trying to create the welded joint between the two sections of the frame, not quite sure if i'm happy with it just yet though...
                      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/frame6.jpg
                      Richard
                      • monsterzeroM Offline
                        monsterzero
                        Holy Cow, dude. Those welds rock! I assume you don't like how the lines pop compared to the rest of the line work. I'm just marveling at the detail. Beautiful stuff.
                        I'd love to know your technique for creating those welds. I have some ideas on how to do it, but you seem to have perfected them. I'd love to put some welds on some of my cars models (for close up renders).
                        monsterzero
                        I live stream my work on my graphic novel:
                        https://www.youtube.com/@monsterz3r0
                        http://infinitemachine.tv/
                        https://www.aaatitle.xyz/
                        • marked001M Offline
                          marked001
                          aw man.... that's dedication! haha.. i think that looks good for the weld.. maybe twice as many divisions on the face of the weld? looks awesome though..
                          http://www.revision21vis.com
                          instagram: revi21on
                          • CraigDC Offline
                            CraigD
                            Yeah! Those welds are amazing! Obviously an aluminum frame design with that nice "dime-weld" pattern!
                            Really great work!
                            Cheers,
                            • CraigD
                            Google SketchUp
                              rsw
                              Thanks for the comments...
                              Heres a quick (simplified) run through of what I did.
                              Note: you need SoapSkinBubble installed for this.
                              (click on the images for a larger view)
                              I've just used a simple cylinder and a flat plane to show you but the principle should be the same for any shape.
                              http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld1.jpg
                              1. create the outer edges of the weld
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld2.jpg
                              2. Draw arcs between the outer edges of the weld (you probably only need 6 segments at most for this)
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld3.jpg
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld4.jpg
                              3. Select the edges of one 'weld' and click the creat skin button (the vcb will control the number of divisions for the skin - i chose 5 or 6)
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld5.jpg
                              4. Once the skin has been created, enter the group and soften all the edges.
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld6.jpg
                              5. Exit the group and click the Generate soap bubble button - the vcb control the 'pressure' - try out a few different values to see which works best - I chose about 300.
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld7.jpg
                              6. Repeat 3-5 until you've gone all the way around the joint. (in this instance the weld could have simply been rotated and copied around the cylinder to complete the weld, but for more complicated shapes this obviously won't work, as each part of the weld could be a different shape)
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld8.jpg
                              Richard
                              • 3 Offline
                                3eighty
                                Just another thought...
                                Does it look better with a texture applied to the weld...
                                http://www.rsw3d.co.uk/wp-content/gallery/sketchup-weld-tutorial/thumbs/thumbs_weld9.jpg
                                (Click to enlarge!)
                                  dylan
                                  This is such nice modelling Richard, welldone.
                                  It would be nice to place this weld tutorial you created over in the SU Tutorials Forum - it's a very good tut you created.
                                  http://dmdarchitecture.co.uk/
                                    rsw
                                    Another update:
                                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame7.jpg
                                    (Click to enlarge)
                                    Thanks! Tutorial created in the tutorials forum.
                                    Richard
                                      SchreiberBike
                                      Totally awesome. ๐Ÿ‘ I've spent a lot of time looking at bicycles and you are hitting everything right on. Of course, you can only get a reflection on a tire if you use ArmourAll on it and that's not good for the rubber. ๐Ÿ˜„
                                      Those welds are masterful, especially making them slightly inconsistent to show that it is hand work. Wow.
                                        dylan
                                        Thanks Richard ๐Ÿ‘
                                          rsw
                                          Continuing to make slow but steady progress with this...
                                          http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame9big.jpg
                                          (Click to enlarge!)
                                          I'm trying not to think about what the poly count and file size of this might be once its complete!
                                          Richard
                                            dylan
                                            Looking great. You have certainly got those welds perfected now ๐Ÿ˜„
                                            • 1 / 4
