    [Tutorial] Create a (TIN) from Surveyed Pts - using SU only
    32 Posts 15 Posters 28.8k Views 15 Watching
    • GaieusG
      James,
      I have sent you an email, please, confirm the delivery...
      • GaieusG
        My problem was that the cad file didn't show up when imported ๐Ÿ˜’.
        Yes because all the Layers were turned off and nothing was on Layer0 ๐Ÿ˜†
        I could hardly find those crosses anyway.
        But now you are really in big problem because moving those points to the proper height will be very tedious. There are some 1800 of the (or 1300?) altogether. And you'll need to re-run the script too.
          andymaw
          Have you had any joy? I'm in exactly the same boat. A number of spot heights (not quite 1300 though!) all in 2d, trying to create an accurate terrain in sketchup
          • GaieusG
            Can you not get the xyz coordinates as just a data file? Those guys must have worked with something as well!
            • AnssiA
              Anssi
              Depending on the type of the information in the DWG, it might not be very difficult to write an AutoLisp routine that would scan a DWG file for points or text entities, and replace them with some small geometric entity (a line, or cross etc.)at the correct height, that could be imported into SU and sandboxed into a TIN.
              Anssi
                jmqrsq
                Scripts reqd:
                points_cloud_triangulation.rb
                delauney2.rb
                Work together - get latest versions
                Download from here:
                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                Thank you Didier.
                I have tried to download the delaunay2.rb script but the links do not work anywhere. can someone send it to me? i can provide an email addy. thanks!
                • AnssiA
                  Anssi
                  So ur saying Anssi that a 2D drawing with points, which is what I have, could be changed into a 3D drawing. That would save alot of work. Can that be done? The Z value would have to be added to each point though, and there are 1300! ๐Ÿ˜’
                  It depends on how the 3D information is displayed in the file. For instance, I have seen many site surveys with the height information as simple text objects strewn around the map, or the height is in an attribute of a block. In both these cases it is possible to grab the 2D coordinates of the object, and use the text contents for the Z information, and draw something there that is importable to SU. A sort of "unflatten" operation. Of course the requirement is that the information is there in some consistent form.
                  Anssi
                  • GaieusG
                    There is a confusion (probably due to a typo somewhere) because this script sometimes is referred as "delaunay.rb" while other times as "delauney.rb".
                    Here is a post where lapx aslo asked for the delauney.rb (which I believe the proper name is) and I posted a copy of it.
                    Try that, hope it works.
                    • E
                      eugenesr
                      Here is the file location of the script:
                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/delaunay.rb
                      and here is the Ruby Script Index page http://www.crai.archi.fr/RubyLibraryDepot/Ruby/
                      Eugene
                      /Fire Fighter! Funny job for an artist, no?/
                      HP laptop running XP
                        andymaw
                        Not been able to check on this for a while....
                        I've had a look at the drawing full of spot heights that I have and they are all at the correct z value....however, it is just text, not crosses etc.
                        Is there a quick way to create these crosses where the text is? I had a look at that autolisp, it looks mind boggling!
                        • AnssiA
                          Anssi
                          This might be a bit OT as you need AutoCad...
                          I took an old Autolisp program I once made and modified it to do this:
                          Scan a selection for text entities. Read the text and convert it to a number and multiply it with an user supplied factor (for unit conversions). Draw a line from the text insertion point to the text upper right corner, using the text as the Z height of the line endpoints. Repeat until all texts in the selection have been processed.
                          The result should be a cloud of small lines that the SU Sandbox from Contours tool can cover with a surface.
                          How it works:
                          • copy the txt23d.lsp file somewhere where Autocad can find it. It should work if put in the same directory as the drawing file to process.
                          • type (load "txt23d") to the AutoCad command line and press Enter
                          • type txt23d and Enter
                          • It asks the user for a selection
                          • It asks the user for a Z scale factor
                          Disclaimer: The lisp has almost none error checking. Scale factor should reset itself to 1 if you forget to give one. It's not rocket science - the real height point may be not exactly at the text insertion.
                          Anssi
                          TXT23D.zip
                            andymaw
                            That did the job! Thanks so much for that. Just got to find the time to put the guide points into SU and it should be sorted.
                            Cheers again
                              Rob D
                              I could really, really, really do with that lisp script... but only have acad LT ๐Ÿ˜ข
                              • V
                                VicBStard
                                How do I get a spreadsheet or comma separated x,y,z points into SU without having to actually position points manually? Is there a way to automate this?
                                Cheers
                                • GaieusG
                                  Sure, use Didier's Cloud plugin; works great.
                                    messire
                                    Hi all
                                    Its getting confusing: the script is installed and delaunay2 installed.
                                    The file is imported from an autocad file with simple points that i put in Z coordinates in acad.
                                    When imported in SU they appears as little crosses ( cannot succeed in zooming on them to see exactly), and when i try to triangulate them, the ruby says " Some objects of the selection aren't construction points". How is this possible since they are all similar and all points?
                                    Nothing happens then..
                                    Is there any way i can resolve this?
                                    I've put a sample from points ( acad) here if anyone has a hint!
                                    http://dl.dropbox.com/u/2095112/3Dpoints.dwg
                                    thnx
                                    Nils
                                      messire
                                      Good lord!
                                      I've found it!
                                      3D points from surveyors are often blocks in acad. When i imported them, i forgot that, and they were in SU still components!.
                                      A simple select all + explode solved the issue and made it possible to triangulate!
                                      Relief!
                                      Sorry for the buzz!
                                      N
                                      • GaieusG
                                        Yup - I was already starting to write this up - good that I read the very last post.
                                        ๐Ÿ˜‰
                                        • mitcorbM
                                          mitcorb
                                          I am tagging this for future reference.
                                          mitcorb
                                          • P
                                            ProfKi
                                            I'm trying to follow this thread to create a 3D landscape. I have the survey points or 'crosses' in SketchUp, all in the correct x,y,z positions. I selected all and exploded the components without any problem. I then reselected all the crosses, and selected the 'Set Centre Point' - but it puts a single construction point in the middle of the drawing - not one at the centre of each cross.
                                            I'm using SU Pro ver 7.1.6860
                                            Can anyone see what I'm doing wrong?
                                            Grateful for any pointers!!
                                            D...
                                            • 2 / 2
