    Dryer Vent?
    21 Posts 7 Posters 2.6k Views 7 Watching
    • GaieusG
      Ah, that's pretty neat!
      Hope you'll share the rendered image! πŸ˜„
      • chippwaltersC
        chippwalters
        Thanks! I'll setup a WIP somewhere on this forum for it soon.
        Currently working with Cross-Reality technologies
        • GaieusG
          Cool. But if you dare to post it in the newbie forum, I'll immediately move it to the render galleries! πŸ˜„
            remus
            may i ask what it is? looks pretty interesting (and a sweet model to boot)
            • chippwaltersC
              chippwalters
              It's going to be an advanced robotic surgery lab...a scene I'm setting up. I'll be sure a post a WIP over in the gallery before the day is done πŸ˜„
              • P
                Pagan
                Quit a chalange task,this video is just to get general idea,of course principle of making this could be expanded of adding more circle in tube,see a video to get idea.
                I'm bad with making animation with SU so i made video.
                I hope this would be useful.
                8.6 MB avi
                http://www.speedyshare.com/857246921.html
                • GaieusG
                  Nice one, Pagan, I was also thinking about a similar solution just thought that working with grouping and grouping already existing geometry may be faster. Also the advantages of using components...
                  Remember when you drew those little line segments to separate the geometry; you can use the Shift+Ctrl+Eraser tool to unsoften them a bit quicker.
                    dylan
                    Im loving your model chip, great work. Looking forward to seeing this progress.
                    http://dmdarchitecture.co.uk/
                    • chippwaltersC
                      chippwalters
                      Pagan, interesting technique, and one I sorta tried at first, but I had too difficult a time selecting the circle cross-section. I can't really see how you did it in the video. It appears you deleted the small line you drew, but I don't see how that selects the circular cross-section. I must be missing something...
                      Thanks for posting the video.
                      • chippwaltersC
                        chippwalters
                        FWIW, I put up some more images in this series over in the gallery at:
                        404 Not Found
                        (www.sketchucation.com)
                        • P
                          Pagan
                          Don't know did I understand your question correct.
                          http://i7.tinypic.com/6pyge3d.jpg
                          http://i8.tinypic.com/6oajyow.jpg
                          http://i14.tinypic.com/8avdvmw.jpg
                          http://i13.tinypic.com/7xx3ur8.jpg
                          http://i3.tinypic.com/81qubr6.jpg
                          http://i11.tinypic.com/6t4pcf5.jpg
                          • chippwaltersC
                            chippwalters
                            OK, got it. Thanks. BTW, after you select the circle polygon, you can right-click on it and choose "Align Axis" then hit the 'S' button for scale, and you will end up with only 4 scale handles which are appropriately aligned, making it much easier to scale the circle polygon.
                            Thanks for the explanation. Good tips!
                            • P
                              Pagan
                              That's good tip too: "Align Axis".
                              http://dhost.info/pagan/emo/152.gif
                              Thanks.
                                dylan
                                Thanks guys, that is a good little method I have not used before.
                                  Masta Squidge
                                  You have to remember though that a dryer vent like that is made up of a spiral not a series of circular wires. At least the one attached to my dryer is. Ive never seen one that is made up of single circles of wire embedded into the covering material.
                                  On a side note that looks REALLY good.
