    Dryer Vent?
    21 Posts 7 Posters 2.6k Views 7 Watching
    • chippwaltersC
      chippwalters
      It's going to be rendered in a different renderer than SU (Podium or Vue or Kirky).
      I'm trying to copy, rotate and scale circles, then hopefully I can loft them together. Just need to find the correct loft plugin πŸ˜‰
      Currently working with Cross-Reality technologies
      • GaieusG
        OK, see attached file for ideas.
        I drew a circle, extruded it to a cylinder, uniformly and about the center scaled the top face to be smaller (general way of "tapering") then slightly rotated it and deleted both circular faces. Made a component of the shape. Then copy moved one on the blue axis, flipped it along the components blue, moved it don to match the closest endpoint then from that point I rotated it around the green axis to align the two circles. Grouped them and repeated the process. You can repeat it as many time as you want aligning the things in different ways to get a "winding" shape (you can group bigger chunks to speed up the process).
        http://www.sketchucation.com/forums/scf/sas/Newbie/DryerVent.jpg
        The skp file
        Note that though this way (turning one section into a conmponent) you will have a fairly small file size, the poly count is still big and you may end upwith a heavy model.
        • chippwaltersC
          chippwalters
          I pretty much ended up doing something similar...used the lofting tool to connect them all.
          Here's how it looks:
          http://www.gadgetplugins.com/chippstuff/armtest.jpg
          • GaieusG
            Ah, that's pretty neat!
            Hope you'll share the rendered image! πŸ˜„
            • chippwaltersC
              chippwalters
              Thanks! I'll setup a WIP somewhere on this forum for it soon.
              • GaieusG
                Cool. But if you dare to post it in the newbie forum, I'll immediately move it to the render galleries! πŸ˜„
                  remus
                  may i ask what it is? looks pretty interesting (and a sweet model to boot)
                  • chippwaltersC
                    chippwalters
                    It's going to be an advanced robotic surgery lab...a scene I'm setting up. I'll be sure a post a WIP over in the gallery before the day is done πŸ˜„
                    • P
                      Pagan
                      Quit a chalange task,this video is just to get general idea,of course principle of making this could be expanded of adding more circle in tube,see a video to get idea.
                      I'm bad with making animation with SU so i made video.
                      I hope this would be useful.
                      8.6 MB avi
                      http://www.speedyshare.com/857246921.html
                      • GaieusG
                        Nice one, Pagan, I was also thinking about a similar solution just thought that working with grouping and grouping already existing geometry may be faster. Also the advantages of using components...
                        Remember when you drew those little line segments to separate the geometry; you can use the Shift+Ctrl+Eraser tool to unsoften them a bit quicker.
                          dylan
                          Im loving your model chip, great work. Looking forward to seeing this progress.
                          http://dmdarchitecture.co.uk/
                          • chippwaltersC
                            chippwalters
                            Pagan, interesting technique, and one I sorta tried at first, but I had too difficult a time selecting the circle cross-section. I can't really see how you did it in the video. It appears you deleted the small line you drew, but I don't see how that selects the circular cross-section. I must be missing something...
                            Thanks for posting the video.
                            • chippwaltersC
                              chippwalters
                              FWIW, I put up some more images in this series over in the gallery at:
                              404 Not Found
                              (www.sketchucation.com)
                              • P
                                Pagan
                                Don't know did I understand your question correct.
                                http://i7.tinypic.com/6pyge3d.jpg
                                http://i8.tinypic.com/6oajyow.jpg
                                http://i14.tinypic.com/8avdvmw.jpg
                                http://i13.tinypic.com/7xx3ur8.jpg
                                http://i3.tinypic.com/81qubr6.jpg
                                http://i11.tinypic.com/6t4pcf5.jpg
                                • chippwaltersC
                                  chippwalters
                                  OK, got it. Thanks. BTW, after you select the circle polygon, you can right-click on it and choose "Align Axis" then hit the 'S' button for scale, and you will end up with only 4 scale handles which are appropriately aligned, making it much easier to scale the circle polygon.
                                  Thanks for the explanation. Good tips!
                                  • P
                                    Pagan
                                    That's good tip too: "Align Axis".
                                    http://dhost.info/pagan/emo/152.gif
                                    Thanks.
                                      dylan
                                      Thanks guys, that is a good little method I have not used before.
                                        Masta Squidge
                                        You have to remember though that a dryer vent like that is made up of a spiral not a series of circular wires. At least the one attached to my dryer is. Ive never seen one that is made up of single circles of wire embedded into the covering material.
                                        On a side note that looks REALLY good.
