    Teaser or not teaser ?
    40 Posts 22 Posters 9.4k Views 22 Watching
    • Didier BurD
      Didier Bur
      Hmm,hmm,
      Good ideas, but I didn't receive the Nobel prize of computer programming (yet) ๐Ÿ˜„
      I'll see what I can do.
      DB
      • T
        tomsdesk
        I wonder what will happen if for SketchUp 7 they made a bunch of tools and then these tools are coincidentally made by Ruby scripters as well.
        The ruby tools will work without screwing up something else!
        2.5D Trees & Shrubs!
        • G
          gata
          That's already happened when SU6 came out. That's life.
            rv1974
            It would be great to have "pick" button to select components in the model space.
              rv1974
              And for me personally the best way to be commercial add-on is to be bought by Google (hope big brother will read this), not by end user
              • jujuJ
                juju
                Awesome scripting there Didier! I can't add any comment that has not already been added - except that I'd like to get this script! So many good things (script wise) on the horizon!
                Hmmm... OK, maybe these comments:
                • Regarding the number of components to be used. I would like to have control over the amount of components that are to be used. Maybe have a list generated in a window so you can track the components used and an "add window" where you point the script to the component you wish to add to the list.
                • Selecting the shape / surface / area. Maybe add an option so you could select and irregular shaped surface and define that as the selection to apply the randomisation and component placement to.
                • JClementsJ
                  JClements
                  Didier, once again you've "pulled a rabbit out of the hat". Congrats.
                  After you get the bugs out of the current script, do you think another script could be adapted from it to paint component along a path (curve)? See a simple example here, http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=3210?
                  The dialog box you have now does scaling, all there would need to be is a couple rotation-on-path options.
                  Regards, John
                  • CadFatherC
                    CadFather
                    how about 'Splasher' - it almost sounds sketchup 5 era to me
                    • Didier BurD
                      Didier Bur
                      Here are the news of the development:
                      Done:
                      • up to 6 components to choose from,
                      • "brush" shapes: point (click to drop a single random component),line, triangle, square, circle, face or faces set (select faces and the script will only drop on these, no matter their shapes)
                      • brush pressure 0 to 100%
                      • option: random rotation of components
                      • option: allow or disallow components stacking
                      • option: keep components vertical or let them follow the slope of faces they are dropped on,
                      • option: put all new components on specified layer
                      • option: allow/disallow random scaling, with min and max scaling values
                      • option: allow/disallow mirroring of components (except along Z, to prevent upside-down components)
                      • option: min and max steepness values (drop components only on a face if its slope is between min and max values)
                      To do:
                      • optimize algorithms for speed,
                      • use/set default settings and advanced settings
                      • drop components between min and max altitude values
                      Regards,
                      DB
                      • ToboboT
                        Tobobo
                        We are definately not worthy!
                        I can't wait, it's like having Christmas twice in one year!
                        Toby
                        Philippians 4:13
                        • GaieusG
                          You're killing me, Didier... ๐Ÿ˜ฒ
                          • jujuJ
                            juju
                            Damn, sounds exciting! I can't wait for this to be released "in the wild".
                              a4chitect
                              man! didier! wonderful, perfect
                              i hope that you would consider adding another important feature to let sketchup quickly design cities, populate roads (man i like it!!!) - alignment (rotation) based by the surface texture, or by any texture. this could help in large scale projects where you could just generate a texture for the road from its path (i created a script for the freeware GIMP that does just that and am willing to share).
                              i know that ruby can access the average color of a texture, but am not sure if you can actually read the pixel color of texture at the point of your raytest interception
                              anyways - maybe it's too much effort, then i'll gladly try to help with this
                              thanks
                              looking forward to the release
                                a4chitect
                                to further promote my point, here is the gimp script this is the gimp script (extract to "..\Gimp\share\gimp\2.0\scripts" and in gimp 'Filters\Render\Circles@Path') to generate path gradient from white to black depending on the orientation. it's not very mature but could be a good starting point for enhancements.
                                there is only one limitation to this script: you are obliged to share any upgrades and modifications for free
                                note: this plugin is already useful when using Vue, there it's possible to align ecosystem objects by texture
                                note2: for a real road you should use 2 paths for each lane with opposite orientation
                                original paths in gimp (for example roads)
                                after the script is finished - ready to place and align components
                                • Didier BurD
                                  Didier Bur
                                  Virtual "coconut beach", with slope and altitude constraints, eh eh...
                                  10 seconds process ๐Ÿ˜„
                                  DB
                                  • ToboboT
                                    Tobobo
                                    Thats amazing!
                                    nuff said
                                    Toby
                                    Philippians 4:13
                                    • I
                                      ilay7k
                                      Didier, nice place...skipy eco-system(like e-on vue) ๐Ÿ˜‰...
                                      i see some ruby technologies from skpPhysics(solids), and ect - era of modificators! ๐Ÿ˜ฒ ๐Ÿ’ญ
                                      • ToboboT
                                        Tobobo
                                        http://sketchucation.com/forums/scf/sas/Ruby/Sandbox1.jpg
                                        This is a mesh created by sandbox. The tool creates the contours as a component.
                                        Toby
                                        Philippians 4:13
                                        • 2 / 2
