    Teaser or not teaser ?
    40 Posts 22 Posters 9.0k Views 22 Watching
      tomasz
      Combined with Kerkythea instancing.. proxy objects.. I was going to write such a tool but it is great Dider had same idea!
      Thanks and looking forward
      Tomasz
      • PixeroP Offline
        Pixero
        Looks lika a great script.
        Is there a limit to how many components you can use. If so it would be good if you could use at least five.
        Here are my thoughts for improvement:
        Please add the possibility for random rotation and mirroring also. (I use a lot of flat "always face camera" trees and mirroring them help cover up that they look alike.)
        It would also be great to be able to click where you want to "plant" a component and it would randomly choose one from the list and random scale/rotate/mirror it. (Some times you want a little more control over where trees goes.) πŸ˜‰
        One more addition is to be able to have the components to follow the normal of the surface instead of their initial good for grass, stones and such.
        And possibly a setting that controls how steep the angle could be for the trees to be planted.
        And finally a question; Will it put all the components in a layer of their own?
        Anyway, looking forward to try this.
        • Didier BurD Offline
          Didier Bur
          Hi Pixero,
          No, no limit (excepting the size of the dialog box) πŸ˜‰ Would 6 be good ?
          Random rotation is done yet. Mirroring is also a good idea, unless I figure out how to do it by script...
          Very good idea πŸ’­ I'll add a "point" shape in the list to do that.
          I had thought about this but didn't implemented it (yet). if you think it is useful, why not ?
          It could.
          Due to the number of settings growing, do you think I must add a "settings" dialog box that will be used if you tell the script to do so, and use defaults if not ?
          What is already done is an option to allow or prevent component stacking.
          regards,
          DB
            kwistenbiebel
            Mighty cool feature !
            This would be great for placing dummy components of trees around a plot and replace them with medium polysized trees just before rendering with your favorite render app...
            And now if Google would make it possible to work with hi-poly files (multicore tech etc...you know), I'd be a happy man.
            • H Offline
              huyvuvn
              sorry all but .... can someone upload that ruby ? I've already seen the swf video and .... that's so good ! I like it !
              happiness on the way, not in the destination.
                Huyvu it seems that Didier is still working on it (also collecting ideas for the development) and the plugin is not ready to be shared yet.
                (I'm also very excited looking forward to it πŸ˜‰ )
                • soloS Offline
                  Awesome ruby in the making, who needs Google to give us the tools we have enough very skilled (geeks) coders/programmers here to take our favourite app further and better.
                    Hehe... True, solo (though the core engine of SU could be improved a little to handle hi-poly models - especially if we have a tool like this πŸ˜’ )
                      rhankc
                      Good Work Didier, and thanks for the show and tell. The possibilities are quite extensive.
                      Hank
                        alexander
                        definitly a teaser..
                        awesome script again Didier.... πŸ˜†
                        • PixeroP Offline
                          Pixero
                          I've thought some more about you script and have some more ideas for you.
                          I think a floating web dialog that stays on top while you work with the tool would be a good idea. Maybe it could have tabs to make the window as small as possible but still have room for lots of settings.
                          At the top there could be four (or more) icons for the different tools: Click placement, Paint placement, Draw region and Select a predefined region from a curve.
                          The paint tool should work like a brush or spraygun that you can set the diameter for the brush. Show the brush size in viewport as a ring and while pressing a specified key and dragging mouse right or left you could change the scale of the brush.
                          As for the amount of different components I belive the more the better. Maybe a possibility to choose a directory and all components in that directory would be used.
                          How does the script choose component based on randomness? Maybe it would be good if it recoginzed the last used component and removed that from the next "selection round" so that two identical components never was used next to each other.
                          When it comes to scaling I believe that a way of choosing what axes it should scale would be good. Many times you might just want to scale it in one or two axes or use different min/max values for different axes.
                          Just my thoughts...
                            Didier Bur
                            Hmm,hmm,
                            Good ideas, but I didn't receive the Nobel prize of computer programming (yet) πŸ˜„
                            I'll see what I can do.
                            DB
                              tomsdesk
                              I wonder what will happen if for SketchUp 7 they made a bunch of tools and then these tools are coincidentally made by Ruby scripters as well.
                              The ruby tools will work without screwing up something else!
                              2.5D Trees & Shrubs!
                                gata
                                That's already happened when SU6 came out. That's life.
                                  rv1974
                                  It would be great to have "pick" button to select components in the model space.
                                    rv1974
                                    And for me personally the best way to be commercial add-on is to be bought by Google (hope big brother will read this), not by end user
                                    • jujuJ Offline
                                      juju
                                      Awesome scripting there Didier! I can't add any comment that has not already been added - except that I'd like to get this script! So many good things (script wise) on the horizon!
                                      Hmmm... OK, maybe these comments:
                                      • Regarding the number of components to be used. I would like to have control over the amount of components that are to be used. Maybe have a list generated in a window so you can track the components used and an "add window" where you point the script to the component you wish to add to the list.
                                      • Selecting the shape / surface / area. Maybe add an option so you could select and irregular shaped surface and define that as the selection to apply the randomisation and component placement to.
                                      • JClementsJ Offline
                                        JClements
                                        Didier, once again you've "pulled a rabbit out of the hat". Congrats.
                                        After you get the bugs out of the current script, do you think another script could be adapted from it to paint component along a path (curve)? See a simple example here, http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=3210?
                                        The dialog box you have now does scaling, all there would need to be is a couple rotation-on-path options.
                                        Regards, John
                                        • CadFatherC Offline
                                          CadFather
                                          how about 'Splasher' - it almost sounds sketchup 5 era to me
                                            Didier Bur
                                            Here are the news of the development:
                                            Done:
                                            • up to 6 components to choose from,
                                            • "brush" shapes: point (click to drop a single random component),line, triangle, square, circle, face or faces set (select faces and the script will only drop on these, no matter their shapes)
                                            • brush pressure 0 to 100%
                                            • option: random rotation of components
                                            • option: allow or disallow components stacking
                                            • option: keep components vertical or let them follow the slope of faces they are dropped on,
                                            • option: put all new components on specified layer
                                            • option: allow/disallow random scaling, with min and max scaling values
                                            • option: allow/disallow mirroring of components (except along Z, to prevent upside-down components)
                                            • option: min and max steepness values (drop components only on a face if its slope is between min and max values)
                                            To do:
                                            • optimize algorithms for speed,
                                            • use/set default settings and advanced settings
                                            • drop components between min and max altitude values
                                            Regards,
                                            DB
                                            • 2 / 2
