    [Plugin] Skin.rb
    237 Posts 66 Posters 173.9k Views 66 Watching
      architectboy
      Well, I'm finding myself forced to enable multiple sides in this version.
        OK - both wishes included! πŸ˜„
          architectboy
          I'm very pleased with what I just did. If you looked at the code for the last version you would have seen a huge 57 line method "connect_rails" that was where all the action happened. Well I just redid that method, making it only 16 lines, adding some functionality to it, and removed some bugs all at once. I'm all πŸ˜„ πŸ˜„ πŸ˜„. Just wait until it comes out, I think this is when it becomes nice πŸ˜‰.
            SchreiberBike
            Elegance in programming is next to godliness.
            • N Offline
              notareal
              Nice work! Thanks.
                architectboy
                So I now have this thing working quite well, but as it is getting close to Christmas I think that I will wait until Christmas to let out the next version, which will hopefully be the final version.
                  architectboy
                  Well, it's the night before when I hoped to have this script done, but I only have a beta version. Tomorrow is packed and the next day we go to the grandparents house. I don't have a tutorial ready yet, and I won't until I bring out the final version, so you will have to figure out the new GUI on your own. But anyway, Merry Christmas and a happy new year to you all! πŸ˜„
                  PS. The clean selection operation currently occasionally locks sketchup up - save before using it!
                  BETA VERSION for version 3.0
                  • JClementsJ Offline
                    JClements
                    I've only played around with skin direct and so far so good. Nice job! I noticed that if the selected curves (edges) are inside a group, that the resulting surfaces are placed OUTSIDE of that group. I like this because this maintains the properties of the original curves (ie., they don't get subdivided).
                    Is there anyway to allow orbiting or panning while the "query" dialogs are on screen?
                      @jclements said:
                      I've only played around with skin direct and so far so good. Nice job! I noticed that if the selected curves (edges) are inside a group, that the resulting surfaces are placed OUTSIDE of that group. I like this because this maintains the properties of the original curves (ie., they don't get subdivided)...
                      Oh is it really like that? I didn't even notice! Realy cool feature (and Darrel, DON'T fix this thinking it's a bug (if you think it is)! πŸ˜„
                      If anyone wants to put the resulting mesh back to the group, he/she can cut/paste in place within the group but keeping the original entity gives a way better advantage.
                        Ross Macintosh
                        Thanks Darrel for all your hard work creating this script.
                        I hope Santa brings you something nice.
                        Regards, Ross
                          lapx
                          Has skin ruby been updated to do a smooth mesh?
                          • F Offline
                            fakircho
                            This is the closest thing to a Loft script for which i have been making requests for years.
                            Thanks Architectboy for all your hard work. Are there any new developments this year around your Skin.rb ? This has a lot of potential πŸ˜„
                              mike d
                              i could not figure this one out
                              The grass is always GREENER on the roof.
                                Masta Squidge
                                Wow I see my auto smooth idea got put in? I 100% forgot that I had suggested that until just now reading through the script. Now coming back to this I think I have to give it a try again.
                                  What are you having trouble with. If you'd like help, give us something to go on.
                                    Sorry but in what Menu or how appear this previous Skin script? 😳
                                      Many thx! πŸ‘
                                      • V Offline
                                        Voder Vocoder
                                        There is a bug in SketchUp where regular Edges - which it shows as stray Edges - are in fact Edges which should smooth with the Soften Edges panel, but do not.
                                        Coen, I think you'll find that if you check "Soften coplanar" in the Soften Edges dialog SU will indeed smooth those edges, and with the slider set well below 180 degrees (like <20).
                                        Voder
                                        • V Offline
                                          Voder Vocoder
                                          I know Voder, but those Edges should be smoothed.
                                          I'm not sure I follow your point, Coen. You have just restated your original premise but offered no rationale. As I said, they are smoothed when you check the soften coplanar check box. When I measure the included angle between the faces that share the edges in question, I get values in the range of ~179.974 to ~180.026. Clearly, within the tolerange range of the Soften dialog, those faces are coplanar, so the behavior of the Soften dialog is consistent, although the faces are not coplanar to the degree of precision that would allow the edges to be removed altogether. Notice, the decimal precision of the Soften dialog is only one place.
                                          I submitted this bug to Google when we were testing v5, but they haven't fixed it yet.
                                          Well that doesn't prove anything other than you thought it was a bug then and you still do now. To me, it seems like reasonable program behavior within the limits of precision of the smooth/soften dialog. Did @Last ever acknowledge that it was a bug? Did they state that they planned to "fix" it?
                                          Voder
                                            architectboy
                                            Wow, I have been gone for quite a while and half expected this topic to be very idle, but apparently I am mistaken. I don't know what to say but that I will see if I can get back to working on this soon, hopefully it won't have to wait until summer break. I'm stunned at how long it has been since I released the last version, which is still lacking many planned features.
                                            • 11
                                            • 12
                                            • 5 / 12
