    Roof.rb v1
    80 Posts 20 Posters 13.0k Views 20 Watching
      Thanks for the feedback so far - even if some of it's reporting problems...
      Can those of you getting problems please report back with PC/Mac ver, SUp version etc and exact nature of problem - e.g. "after dialog nothing gets made and there are no error dialogs either"... [it would help when you get the problems if you have the Ruby Console Window open and copy me in on any errors that pop up there too]... so I can see if there's a common problem...
      Works fine for me (and several others) with PC XP SP2 and Vista SUp 60515.
      • boofredlayB Offline
        boofredlay
        TIG, I tried it out at home and I get the same results as above.
        Both computers=
        PC
        XP service pack 2
        SU 6.0.515
          dylan
          PC XP Service Pack 2
          SU 6.0.515
          Will not work, nothing happens.
          I create a rectangle and push/pull.
          Highlite top surface/plugins/roof
          Choose whichever version, mansard,gable etc, but nothing happens after this when I would expect the roof to be created.
          I will give it a go shortly on my Vista Laptop, see if it works with that system.
          http://dmdarchitecture.co.uk/
            Both computers=
            PC
            XP service pack 2
            SU 6.0.515
            Same spec' as I have tested it on and it's perfect ! Very confusing...
            Videos cards [long-shot] ?
            Any Ruby Console Error Messages when it is failing ?
              marne
              works perfect for me. thank you, great script.
              i use xp sp 2 and SU 6.0.515 and it works, it must be anything else...
              http://xs218.xs.to/xs218/07346/Untitled1234134.jpg
                Thanks for some positive feedback.
                Perhaps it's a script clash - this might show in the Console messages ?
                The script is packed but its classes include:
                class Geom::Vector3d >>> to_flat_angle
                class Geom::Point3d >>> is_on_face?
                class Sketchup::Face >>> offset_eaves(dist)
                and then...
                Roof itself has a class 'Roof' with methods:
                Roof::hip()
                Roof::mansard()
                Roof::gable()
                Roof::pyramid()
                Roof::get_slope()
                Roof::help()
                • plus for data manipulation...
                  Roof::ordered_edge_points(face)
                Anyone know of clashing class/methods in other scripts etc ?
                  Eric, you had trouble with the .mht file showing images.
                  Does you Internet Options > Advanced window look like this ?
                  It should.
                  http://www.sketchucation.com/forums/scf/sas/Ruby/IOsettings.jpg
                    rhankc
                    I am happy to report, initial test produced a roof, a gable roof over a rectangle. I toggled all the menu settings, included the carat, used degrees rather than rise/run, inches rather than ft in,
                    made a rectangle 30 degree pitch gable
                    attempt to make another gable, I get the attached jpg.
                    Then I work with the hip settings:
                    this is the ruby console error when making hip w/ ^45 pitch
                    BulkChange: 1
                    BulkChange: 2
                    Error: #<NoMethodError: undefined method to_f' for ["^45"]:Array> (eval):163:in dialog_hip'
                    (eval):189:in hip' (eval):2720 (eval):2720:in call'
                    using 45 w/out the carat doesnt change anything
                    The most prevelant message is th jpg, it isnt allowing any repeat roofs
                    Nvidia GE Force 7300 LE
                    XP SP2
                    SU vers 6.0.515
                    anything else I can test, let me know
                    Hank
                      rhankc
                      I am getting better with it!
                      I am getting repeat roofs in the smae file. When it quits I close itt down and start another and do it till it gets the jpg. posted earlier
                      if I enter for pitch; ^45, it seems to me I would get a 12:12 pitch, but I get 12.4 degrees
                      enter ^68 I get a roof at 20.9 degrees.
                      In the help guide It says enter decimals or on the menu enter inches and when inches are entered on the menu, it shows as feet. example enter 24", it shows as 2'
                      Hank
                        rhankc
                        I think you are misunderstanding how to enter the roof 'slopes'. It is done differently for hip/mansard and gable/pyramid roofs.
                        For a hip or mansard/sprocket roof you can only enter the roof slope as an angle in degrees [a number] e.g. 22.5, OR the slope as a ratio [separated by ':'] e.g. 2:5. For these types you CAN'T enter a ridge/apex height using a ^. If you do it should return an error thinking you've entered zero degrees
                        For a gable or pyramid roof you can enter the angle or ratio as above OR additionally you can specify the ridge/apex height above the fascia in current units by prefixing it with a ^, e.g. ^1234 (here assuming mm this puts the ridge/apex at 1234mm high). Don't use a units suffix or try '/" - so 1234.5 (in mm) is OK as is 18 (in inches) or 1.5 (in feet) but NOT 1'6".
                        When you make a hip or mansard you need to have one horizontal face selected otherwise you'll get error messages.
                        When you make a gable you need to select one face that's both horizontal and forms a rectangle, AND also select an edge that's near where you want the 1st gable to be (that's needed to tell the tool which of the rectangle's sides are to form gables and which of them is the 1st one, since you can apply different settings to the 1st and 2nd gables).
                        When you make a pyramid you need to select one face that's both horizontal and forms a rectangle, AND also select an edge that's on a side where you want the angle for the slope to be taken from - with a non-square pyramid the two pairs of opposing faces have different slopes so you need to do this to indicate which gets the degrees/ratio you've given. Note that you need to select one of this rectangle's edges even if you intend later to use ^1234 as the height of the apex instead of entering degrees or a ratio, as at the point where you set off the tool has no way of knowing what options you might choose later...
                        Your item about it saying inches in the menu prompts and it showing it in feet is a function of SketchUp: if you are working in Architectural units - inches - and you enter 18" it's taken OK but when you reopen the dialog it will show 1' 6" - the prompt simply tells you that your current units are set to inches [or feet or cm or whatever] - SketchUp displays Architectural inches as feet+inches if it's >12".
                          boofredlay
                          It should.
                          Here is mine at home, I won't be able to check work until Monday.
                          http://www.sketchucation.com/forums/scf/sas/Ruby/Internet-Properties.jpg
                            rhankc
                            Thanks for the detailed explanation.
                            I get pyramid roof no problem. I havent tried a mansard, but I will.
                            The only way I can get gable to respond is using a ^ before a specified height. The other techniques dont produce anything. I was seeing the difference in what was entered for eaves etc. and thought it was a SU thing so I had changed my units to decimal-inches and was still getting the ft-in after entering a value in inches. That is why I mentioned it. it is now entering as expected.
                            After a few roof sessions, (keep making different roof modules) I get the image I posted earlier even though I have the edge and horizontal surface selected. It wont get over the message until I start a new file.
                            This is going to be a great tool. thanks
                            Hank
                              @rhankc said:
                              The only way I can get gable to respond is using a ^ before a specified height. The other techniques dont produce anything...
                              IF you open a new model, open the Ruby Console and then make a rectangle + push'pulled to a volume, then run Roof...Gable and accept all of the defaults that appear in the dialog what happens ?
                              With your 'non-rectangle' error... it's as if multiple editing make what is a rectangle slightly skewed. Maybe I need to build in some 'tolerance' as to what makes a 'rectangle'...
                                rhankc
                                that is the perfect question...
                                the first run after the initial boot, I built a rectangular cube, and ran the roof tool on gable after selecting one edge and the top plane. I saw nothing happen.
                                I did it again exactly as you described for a gable: nothing happened.
                                To get a roof model the first attempt, this is what I tried: I went thru the menu and toggled each setting, basically rekeyed everything there and entered 12:12 for a pitch. I got nothing; then I noticed the ^ wasn't included in the pitch indicator, so I set ^12 , and got a low pitch roof.
                                here is the ruby console script:
                                Added: 1 :: #Sketchup::Face:0x4e3ad38
                                Cleared: #Sketchup::Selection:0x4e58480
                                Added: 1 :: #Sketchup::Face:0x4e3a0c0
                                BulkChange: 1
                                BulkChange: 2
                                Error: #<NoMethodError: undefined method to_f' for ["1", "2"]:Array> (eval):1385:in dialog_gable'
                                (eval):1494:in gable' (eval):2722 (eval):2722:in call'
                                Hank
                                • H Offline
                                  humanticnc
                                  hi halli
                                  http://www.sketchucation.com/forums/scf/sas/Ruby/roof-1.png
                                    dylan
                                    Just tried this on Vista also with SU Pro latest version and still does not work.
                                      rhankc
                                      Dylan,
                                      There is definatly some technique to it, but when there is a roof drawn it is a pretty thing! I think there is alot of computing power going into this thing. Try a gable, Use the ^ (carat) or whatever it is,enter a # rekey all the menu settings, should give a roof.
                                      Hank
                                        This is a real mystery... but it shall be solved.
                                        If you open a new model, open the Ruby Console, make a rectangle, pushpull it into a box, select the top face and an edge belonging to that face (with Shift or Ctrl) and run the tool Roof...Gable..., then accept all of the dialog's defaults with an OK what happens ? Any error or console messages, is there a group made where the roof might be, etc.
                                        I appreciate that its not working is frustrating for you, BUT it's doubly frustrating for me when it seems to works in identical set-ups elsewhere without any hitch, and you're not giving me many clues as to what's wrong - except that, "it's not working..."
                                        I appreciate your feedback, but please can it be a bit more detailed...
                                          rhankc
                                          wish I had three monitors for this:
                                          New untitled.There is a template here
                                          Here is the first step:Ruby console on:Rectangle push/pull into cube:
                                          console text:
                                          Added: 1 :: #Sketchup::Face:0x4415260
                                          Cleared: #Sketchup::Selection:0x4438480
                                          Added: 1 :: #Sketchup::Face:0x44148e8
                                          Select edge and plane:
                                          BulkChange: 1
                                          BulkChange: 2
                                          Plugins>Roof>got the message I attached earlier. Going to start over.
                                          new untitled, and all the way to the flyout at gable selection was the same except this time I got the Gable roof setting menu.
                                          Accept all defaults>OK
                                          The box plane & line is still hi-lited and absolutely nothing happened, no flash or resemblence of a roof.
                                          Here is the last sequence of commands ruby console text:
                                          I am going to load another start template, if it works any better I'll let you know.
                                          Hank
                                            rhankc
                                            Ok, I fired up my laptop which has XP 2002 SP2 and a ATI Mobility Radeon X600 G.C. that has a version of 5 & 6 on it but no rubies to speak of:examples.rb,RPS_Ray Trace.Rb, Utilities.rb,parametric.rb,oniondome.rb,bezier.rb,grid.rb,windows.rb,shapes.rb, rectangle .rb, and the roof.rb
                                            There are very few inhibitors here, and I could possibly uninstall all but the defaults if you think they may be in the way.
                                            I had the same response as the previous attempt, which is no group, stuff still highlited etc. on both versions.
                                            Hank
                                            • 1 / 4
