    Free sketchup or sketchup pro?
    31 Posts 8 Posters 4.7k Views 8 Watching
      Sawduster
      On the legal side, if I remember correctly, the free version is not licensed for commercial use, so if you're doing it for money, then . . .
      May all your dimensions be the sum of their total.
      Jerry
      http://www.sawdustersplace.com
      • AnssiA Offline
        Anssi
        In fact the free version CAN be used commercially, the agreement wording has changed from v.5.
        The main difference between the versions is that Pro has Layout and vector-based output formats (DWG, DXF, PDF, 3DS, OBJ...)
        Anssi
          Yes, true, they left the "commercial thing" out of the free version now.
          • N Offline
            not registered yet
            Well, thank you all so much. It seems like the pro version would be the one to enable me to export in the formats I want to.
            I'd like to try Vectorworks sometime. Does anyone know of a free demo?
            P: joanffolliott
            • EdsonE Offline
              Edson
              try their site: http://www.nemetschek.net/
              http://www.mahfuz.arq.br
                sorgesu
                At one point I heard that the export resolution on raster files had a lower limit than in the Pro version. Is that true/still true?
                Susan Sorger
                Former Seller Hand Rendered Entourage
                Former Canadian Authorized Training Centre, SketchUp
                • Chris FullmerC Offline
                  Can the true free version import dwg files? or is it the Pro trial that is importing. One other concern is that the free won't output to dwg if ever needed.
                  Finally, if you are getting dwg files from clients, it seem slike SU might have problem with them if they are not trimmed down correctly. I don't know how elaborate they come in your line of work, but I can't imagine using SU to edit the CAD files created by my firm, just because of the detail and size of the dwg file.
                  I'm sure there are plenty who would disagree though.
                    Susan,
                    In SU5 (free) trhere was a restriction of 2D image output to screen resolution. Now in SU 6 (free) this is the same as pro.
                    Chris,
                    The import functions of the two versions are the same - the difference is in the export functions of 2D models: the free version only allows kmz export (i.e. to Google Earth).
                    The only other difference is that (in the Windows version) there is no location option in the Model info in the free version (I just learned that in the Mac version there is, here on the forums πŸ˜„)
                    And, of course, LayOut...
                    (In the office I work I only have the free version installed so I can check regularly - Google has eliminated most of the differences between the two versions)
                      @gaieus said:
                      The only other difference is that (in the Windows version) there is no location option in the Model info in the free version.
                      I sort of didn't believe you when you said that there is no model location ability. So I looked it up and sure enough, they took it out! I think that's crazy. Of course there is the workaround of opening google earth and zooming to the location of your model and then importing that terrain. That will set your SU model to the correct coordinates. But that's sure a long way around it.
                        Also Jim Foltz made a ruby that puts location into the free version, too.
                        • EdsonE Offline
                          Edson
                          do you where can it be downloaded from? i looked for it in our repository but could not find it.
                            We've already had this discussion, Edson, remember?
                            Well, it's listed here:
                            http://jim.foltz.googlepages.com/plugins_index.html
                            But you are on Mac, Edson, and the free SU for Mac has the Location afaik
                            • EdsonE Offline
                              Edson
                              sorry, gai, i did not remember it. yes, i am on mac but most of my students are not so the script will be useful to them.
                              thanks.
                                Yeah, I thought so.
                                Thank Jim, not me!
                                πŸ˜„
                                  Goggin
                                  I'm in a similar mode-- trying to decide whether to go pro or not.
                                  The big drawbacks of the free version for me are
                                  1. Difficulty in printing large (11 x 17 or 24 x 36) copies of blueprints.
                                  2. Exporting to .dwg format.
                                  If I have to have those two features, is there any option other than going pro?
                                  Thanks. This is my first post here. I've been using SketchUp for about 2 weeks now, and I just found this MB a few days ago. Lots of good info here!
                                    Goggin,
                                    First of all, welcome - though you found us in the middle of a move (so please, read the announcement right now).
                                    As for your problems:
                                    1. works the same in the Pro and the Free versions now. Really no difference.
                                    2. Exporters are different. You need the Pro version to be able to export 3D models from (native) SU.
                                      Goggin
                                      @gaieus said:
                                      Goggin,
                                      Thanks. Which announcement are you referring to? The one in this forum? I read that.
                                      Interesting. I thought that pro allowed you to easily select the scale, but that the free version didn't. If I want to print to scale at 24 x 36 (say 1/4" = 1'), do I draw a border around the plans so that printing to that border produces the desired scale? Otherwise, how would the program know how to scale things?
                                      My only printing experience so far has been limited (I assume) by the ability to print only what is viewed on the screen at the time. Maybe I'm missing something...?
                                        In order to print to scale you have to make sure that
                                        • you use "parallel projection" (not perspective view - see in Camera menu)
                                        • set one of the "standard views" (also Camera menu - or from the toolbar)
                                        • in the Print dialogue uncheck the "Fit to page" checkbox and there you go; on the left you can set your scale.
                                        Note that if your model cannot fit on a page by the set scale, you have an option in the very bottom left corner to print it on tiled sheets.
                                          Goggin
                                          Thanks. I'll have to try that. From the SketchUp Help section on Printing, I read this to mean that you needed the pro version to print to scale:
                                          PROPrint Size
                                          The Print Size section of the Print dialog box is used to adjust the physical size of your output.
                                          Fit to Page: The Fit to Page option is used to size the model to fit on a single sheet of paper. This option must be disabled in to specify a different size or scale.
                                          Page Size: The Page size fields are used to enter a custom page size for your output.
                                          Scale: The Scale fields are used to scale your model for printing. The first measurement, labeled In the Model, is the measurement of the exported geometry. The second measurement, labeled In SketchUp, is the actual measurement of the object in real scale. For example, for a scale of 1/4" = 1', simply enter 1 inch In the Printout equals 4 feet In SketchUp.
                                            Yes but that's because they forgot to update that after SU6 was released in which version this - and quite a lot of other things - were made available in the free version, too.
                                            In my office I only have SU free (it's a machine others may have access too and the Pro license is mine not that of the office) so fortunately I can follow all the differences.
