Creating balister need woodworker help
Ray, here is Jean's in V5
@woodtogo said:
I am using green rotate tool and it pulls everything, face and all.
You're using the correct tool (Rotate,) but you need to toggle the 'copy' mode by tapping the <ctrl> key. Description in the Users Guide:
Regards,
Taff -
If you have version 5, the upgrade to 6 is free. If you upgrade you can use some of the new ruby scripts like:skin.rb to stitch things up for you.
You might actually find this version a little faster. It is using the Sandbox Tools to create the desired surface. BTW, you either have the blue axis in the wrong direction or you are intentionally lying the balustraude down on the ground as you build this. It really could be created vertically as it is in my example.
Ha!
Just about everyone had to edit or amend their post to provide a version 5 model (including me.) I guess that demonstrates an advantage provided by the 3D Warehouse. Any version 6 model gets a version 5 model, added automatically to the download options:
http://sketchup.google.com/3dwarehouse/details?mid=1c0f9db2221fe9bc387ecd6083924dba
Regards,
Taff -
Thank-You Susan, your method looks easy to me, but being a newbe, I don't think I have a sandbox tool, at least on my version 5. I have looked and can't seem to find it, unless it is hiding somewhere. The help file does not tell me where to get the sandbox tool.
Ray
Ray,
If you use the free version (?), you won't have the sandbox tool in SU5 just in SU6.
If you have the pro version, first you need to activate it at Window > Preferences > Extensions and then put the toolbar to your window from View > Toolbars.
In either case however I'd take Susans advice and upgrade to v.6.
Gai,
Ok found it never knew I had it thanks.
What a lot to learn.....Ray
Susan,
Thank-You your tutorial was by far the easiest for me to do and follow. I only wish I knew what it was that I was doing. I will try to find all the tutorials on sandbox now and study them to see what else I can do with this tool. I will also work on all the other replys I got and study all the methods used to accomplish this drawing. I only wish I could understand the theory behind what it is I am doing. Taff had the most logical explanation to me, in that a chisel was turning around the stock, and that I can relate to. I feel like a monkey just copying all you guys directions and not knowing what is actually taking place here. But I thank you all for all your help and I have learned that there is more than one way to do what you need to do. Its like learning windows, there are many ways to accomplish the same thing. Everyone was a great help to me Glad to be in touch with such a great bunch of people.Ray
Susan,
After studing you tutorial, I realized that my spindle is 1 1/4" dia and does not quite fit the 2" dia on my turned base. It just doesn't look quite right, so I have enclosed a copy of my version of the fix I made. I use the technique I learned from you and replaced the 2" circle on the top to 1 1/4" circle raised it 1/4" above the base then followed you advise and used the wonderful sandbox tool, (from contours), and bingo a great looking base for my balisters. Again thanks. -
Looks Fabulous to me! I'm glad to be of some use
