    A kickass UI using WebDialogs and DHTML Suite.
    20 Posts 13 Posters 3.9k Views 13 Watching
    • T
      todd burch
      Prettttttty cool!
      Todd
      • PixeroP
        Pixero
        Thanks for the link. πŸ˜‰
        • T
          tomasz
          Chris,
          It is amazing. My head is exploding πŸ˜’
          Bye Bye Simple input boxes. I just have to wait for the weekend πŸ˜„
          I hope connecting it to SU is easy.
          Thanks a lot!
          Tomasz
            diana
            This looks so very nice and I do like how the sections scroll.
            • N
              not registered yet
              That looks really nice!
              [crojack]
              • boofredlayB
                boofredlay
                Eagerly awaiting.
                • Y
                  ypnos1
                  OMG
                  That is cool
                  and i feel like such a dork for being so exited about somethign like this
                  thanks πŸ˜„
                  • C
                    CPhillips
                    Update, I hooked up the UI to actually send updates to Sketchup any time a value changes. It was pretty easy but I am very glad I waited until I had the layout finished. Maintaining all the names and events is tedious when you are doing a lot of copy/paste of elements.
                    Unfortunately I think I went a bit overboard with the UI. It works fine, but from a user perspective it looks too cluttered and complicated. I am going to break it up and simplify it.
                    If anyone wants advice on how to get one of these running ask here.
                    • T
                      tomasz
                      Chris,
                      I am interested. Give us a guidance, please.
                      Thanks in advance.
                      Tomasz
                      • W
                        Whaat
                        Did you do the layout by hand-editing the HTML files or did you have layout software to drag and drop, cut and paste, edit colors, etc.?
                        Also, did you find any useful online resources for learning HTML and javascript or did you just try and figure it all out on your own?
                        Thanks for sharing this...
                        • C
                          CPhillips
                          Chris,
                          Thanks in advance.
                          Tomasz
                          I meant that if you wanted to build a dhtml suite dialog I would give you advice. Do you have a UI in mind?
                          • C
                            CPhillips
                            I did it by hand. I looked and looked for a good layout editor and came up with nothing that was suitable.
                            Finally I bit the bullet and started doing the html code by hand. It wasnt nearly as bad as I expected. And I now kinda understand why none of the html layout tools are any good. Its more like writing code than a layout. BTW I use SCite as a html aware text editor).
                            The dialogs\simple.html example shows pretty much just the basics.
                            • T
                              tomasz
                              I meant if you could show us how you have connected html and Ruby. How you pass results back to Ruby.
                              Tomasz
                              • C
                                CPhillips
                                Tomasz
                                Ah. Well you don't need dhtml suite for that.
                                Here is the ruby code that launches a very simple html dialog:
                                def showVerySimple()
                                    #create
                                    dlg = UI;;WebDialog.new("VerySimple", true,"verysimple", 300, 300, 100, 50, true)
                                    fn= File.dirname(__FILE__)+'/verysimple.html'
                                    dlg.set_file fn
                                    dlg.show {} #show it
                                    #create a callback for anytime a value changes in the dialog.
                                    dlg.add_action_callback("ValueChanged") {|d,p|
                                            puts p
                                The "add_action_callback" code at the end allows the dialog to communicate with sketchup. The "puts p" will print out the name and value of a control that changed.
                                Here is the HTML:
                                <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
                                <HTML>
                                	<HEAD>
                                    <title>Webdialog UI </title>
                                	</HEAD>
                                	<body>
                                        <div>
                                            <font color="blue">Checkboxes</font><br>
                                            <input type="checkbox" name="check-one" onClick="tellSketchup(this.name,this.checked)">One</input>
                                            <input type="checkbox" name="check-two" onClick="tellSketchup(this.name,this.checked)">Two<br></input>
                                            <input type="checkbox" name="check-three" onClick="tellSketchup(this.name,this.checked)">Three</input>
                                            <br>
                                            <font color="blue">Radio</font><br>
                                            <INPUT type=radio name="radio" value="radio-a" onClick="tellSketchup(this.value,this.checked)">Aye
                                            <INPUT type=radio name="radio" value="radio-b" onClick="tellSketchup(this.value,this.checked)">Bee
                                            <INPUT type=radio name="radio" value="radio-c" onClick="tellSketchup(this.value,this.checked)">See<br>
                                        </div>
                                   		<script type="text/javascript">
                                           function tellSketchup(name,value)
                                                    //this non-intuitive command will call the sketchup callback "ValueChanged"
                                                    //with the name and value of the control that changed
                                               window.location='skp;ValueChanged@'+name +"="+ value;
                                       </script>
                                    </body>
                                </HTML>
                                The HTML creates three checkboxes and three radio buttons. Anytime a user clicks on a control (ie. changes it) the "onClick" code is called. In this case it calls a javascript function called "tellSketchup". That function simply passes the info to sketchup in the form of a string like "check-one=true".
                                Thats it!
                                404 Not Found
                                (www.sketchucation.com)
                                  Jim
                                  It comes down to passing Strings from the javascript to the ruby callback by setting the window.location and using the skp: prefix.
                                  // this is javascript
                                  window.location = "skp;somecallback"; // no paramters
                                  window.location = "skp;somecallback@" + someString;
                                  # this is ruby
                                  dialog.add_action_callback("somecallback") do |d, a|
                                    # d is the dialog
                                    # a is the string passed after the @ in the javascript
                                    puts "somecallback called;#{a.inspect}"
                                  • H
                                    herodes
                                    Can someone repost the VerySimpleDialog.zip file that was on this thread?
                                    I'd like to have a look...
                                    %(#BFBFBF)[http://arhitektonas.blogspot.com
                                    I know me,... I am that guy...
                                    • GaieusG
                                      Fixed. Thanks for notifying.
                                      • fredo6F
                                        Chris,
                                        That's a very neat job and a damned good idea to enhance interactivity for some plugins requiring options and being context sensitive for actions (The Sketchup tool bar is actually very limited to interact efficiently and the button state management of Sketchup is simply buggy).
                                        I guess this works for Mac too.
                                        As soon as I can, I'll give it a try to regroup some commands of my plugins (Bezier, JPP, OOS, etc...) as it will be easier to show the options.
                                        PS: your dialog box is very esthetic. I like very much the design. And if you allow me, I will take some inspiration of it when I try one.
                                        • C
                                          CPhillips
                                          Thanks Fredo6. Feel free to copy any part of it. πŸ˜„
                                          Chris,
