    Modeling the perfect rafter?
    9 Posts 5 Posters 1.6k Views 5 Watching
    • N Offline
      not registered yet
      I have my pitch where I want it, but I cant model the seat cut for the rafter to sit down on the top plate. Sorry if the wording is confusing, I am a general contractor and know how to make it in the field, but having a hard time using SU!
      I am attaching some images of what I have done so far.
      http://i239.photobucket.com/albums/ff208/Cole_22_2007/Garage1.jpg
      http://i239.photobucket.com/albums/ff208/Cole_22_2007/Garage2.jpg
      http://i239.photobucket.com/albums/ff208/Cole_22_2007/Garage3.jpg
      P: Online
        tomsdesk
        Draw the rafter cut on the face of the rafter (like you would in the field), then use th pushpull tool to push that triangle over to the other face of the rafter.
        http://www.sketchucation.com/forums/scf/sas/Newbie/Garageraftercut.jpg
        2.5D Trees & Shrubs!
        • N Offline
          not registered yet
          Thank you, I knew there would be an easy way!
          P: Online
          • KrisidiousK Offline
            Krisidious
            house builder rb... by Didier
            merry christmas... http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1518
            this ruby will build these things for you, over spans that you dictate. it automatcially sets for the bird's mouth although it does not cut it out.
            By: Kristoff Rand
            • N Offline
              not registered yet
              I cant seem to get it to work.
              Nevermind, I figured it out!
              P: Online
                Krisidious
                oh ... a tease huh?
                I see how you are...
                By: Kristoff Rand
                  Sawduster
                  You been pretty quiet lately Kris. Been away?
                  Cutting the birds mouth would be the easy part. Shifting the rafter and associated stuff attached to it dcown to seat on the plate would be the tough part. Setting the rafter for the bird mouth from the get-go is the ticket.
                  May all your dimensions be the sum of their total.
                  Jerry
                  http://www.sawdustersplace.com
                  • N Offline
                    not registered yet
                    Wouldn't it be pretty easy to just make the cut-out on a rafter using the mentioned push/pull (I'm assuming the rafter is a component, so the cutout propagates through all rafters), then simply select all the rafters "and associated stuff attached to it" and use the move tool to move it straight down onto the top plate?
                    P: chemtech
                      Scotty T
                      Group your walls then go into edit of that group.
                      Create one rafter and make it a group.
                      While still in edit of the wall component intersect with the rafter.
                      If you notice at the birdsmouth you can delete the section of the BM setting on the top plate.
