    Click-drag-release vs. click-move-click
    17 Posts 12 Posters 3.2k Views 12 Watching
    • N
      not registered yet
      I didn't realize there was an option there. I'm excited to try it out. I think I'd prefer the non-dragging edit as Sorgesu has talked about. I can see where that would be easier, especially using the push/pull.
      P: AcousticGarden
      • boofredlayB
        boofredlay
        @sorgesu said:
        ...I do make one exception. I always drag the offset tool. I find that it is so sensitive that when I click release I have finished the offset before I intended to. So I drag that one.
        I am with you on this one Susan. The offset is really annoying at times.
        Click move click is my method of choice.
        • GaieusG
          I also use click-move-click from the very beginning exactly for those reasons; orbiting and panning in the meanwhile sometimes to get an inference point makes it easier for me.
          But the best way is what you get used to and what is convenient for you.
          • B
            Bill Wilson
            Too many choices mean too many problems, why isn't everything simple? Like me! πŸ˜›
            Cheers & Beers
            Bill
              rsw
              I use the click-move-click method for nearly everything.
              This is the way i've always used it from when I first tried SU (ver 3 I think) but its probably because of using other programs like autocad before SU and is therefore what I'm most used to and comfortable with.
              Richard
              http://img.userbars.pl/98/19554.png
              http://i158.photobucket.com/albums/t106/671GUAMDUDE/Animated---User-Green.gif
                SchreiberBike
                Looks like click-move-click is the way to go then. I'll keep on adapting.
                • Jean LemireJ
                  Jean Lemire
                  I folks.
                  I use click-move-click nearly all the time for the same reasons that have been written by others (ability to pan, zoom, orbit, change scene, change rendering mode, etc, during the move).
                  Dont forget that you can also use press-drag-release even if the other method is enabled.
                  Just ideas.
                  • N
                    not registered yet
                    After playing around with it, I like that it will auto-detect what you're trying to do, so you could conceivably use a combination of both methods.
                    P: AcousticGarden
                    • N
                      not registered yet
                      While we're on the topic, has anyone else come across problems with bluetooth mice. The wheel button doesn't orbit or pan(shift) somehow?
                      I've tried regular and USB mice and they all seem to work.
                      P: ACZero
                      • O
                        otb designworks
                        Try setting your scrollwheel button to 3 in your preferences. I am using a bluetooth Logitech mouse with my Macbook Pro and this is what worked for me. No mouse drivers necessary.
                        Cheers, Chuck
                        OTB Designworks is on Youtube
                        • ToboboT
                          Tobobo
                          I use a mixture of both, to honest i don't really think about it. I just do it.
                          Toby
                          Philippians 4:13
                          • N
                            not registered yet
                            Thanks Chuck,
                            I tried setting the scrollwheel button to 3 and then installing the software later. Both methods didn't work. How frustrating! 😠
                            Is your mouse the Logitech V270 Cordless Optical Bluetooth?
                            Cheers.
                            P: ACZero
                              dylan
                              Slightly off topic, but ACZero that is just the best avatar! πŸ˜„
                              http://dmdarchitecture.co.uk/
                              • N
                                not registered yet
                                Thanks Dylan,
                                I thought our familiar friend needed some new groovy gear and party a little. Might even make him my default dude. 😎
                                P: ACZero
