    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Click-drag-release vs. click-move-click
    17 Posts 12 Posters 2.7k Views 12 Watching
      SchreiberBike
      When I started using SU, I found that the System Preferences/Drawing/Click Style of click-drag-release was more intuitive, so I specified that option. Now, I've read in the SketchUp for Dummies ๐Ÿ˜ฎ book that click-move-click worked much better in SU. So, I've been trying that for a while and I'm finding that though it has an advantage in making it easier to orbit or zoom while drawing, generally it confuses me more.
      Does anyone else agree with the book or otherwise have strong opinions? How do you click in SU?
      Thanks,
        sorgesu
        with most tools I was click releasing, moving click to finish.
        There were exceptions, notably the Push Pull tool.
        When I started training I was encouraged to get rid of all such bad habits, and though it was difficult to make the change, I got used to it fairly quickly and must admit that inferencing the push pull when you hands are loose and you are not dragging with the left button down, is actually much easier.
        The only tool you must drag of course is the freehand tool. I do make one exception. I always drag the offset tool. I find that it is so sensitive that when I click release I have finished the offset before I intended to. So I drag that one.
        Susan Sorger
        Former Seller Hand Rendered Entourage
        Former Canadian Authorized Training Centre, SketchUp
          robmoors
          I dont know never really tought about it but now when you mention it, I use a click move click normally, but when using push pull, follow me, scale, and offset I use click drag, mustve transferred over from other 3D programs.
          My advice use whatever comes natural to you and don't think about it.
          Rob Moors
          Architecture Student
          • N Offline
            not registered yet
            I didn't realize there was an option there. I'm excited to try it out. I think I'd prefer the non-dragging edit as Sorgesu has talked about. I can see where that would be easier, especially using the push/pull.
            P: AcousticGarden
            • boofredlayB Offline
              boofredlay
              @sorgesu said:
              ...I do make one exception. I always drag the offset tool. I find that it is so sensitive that when I click release I have finished the offset before I intended to. So I drag that one.
              I am with you on this one Susan. The offset is really annoying at times.
              Click move click is my method of choice.
                I also use click-move-click from the very beginning exactly for those reasons; orbiting and panning in the meanwhile sometimes to get an inference point makes it easier for me.
                But the best way is what you get used to and what is convenient for you.
                  Bill Wilson
                  Too many choices mean too many problems, why isn't everything simple? Like me! ๐Ÿ˜›
                  Cheers & Beers
                  Bill
                    rsw
                    I use the click-move-click method for nearly everything.
                    This is the way i've always used it from when I first tried SU (ver 3 I think) but its probably because of using other programs like autocad before SU and is therefore what I'm most used to and comfortable with.
                    Richard
                      SchreiberBike
                      Looks like click-move-click is the way to go then. I'll keep on adapting.
                      • Jean LemireJ Offline
                        Jean Lemire
                        I folks.
                        I use click-move-click nearly all the time for the same reasons that have been written by others (ability to pan, zoom, orbit, change scene, change rendering mode, etc, during the move).
                        Dont forget that you can also use press-drag-release even if the other method is enabled.
                        Just ideas.
                        • N Offline
                          not registered yet
                          After playing around with it, I like that it will auto-detect what you're trying to do, so you could conceivably use a combination of both methods.
                          P: AcousticGarden
                          • N Offline
                            not registered yet
                            While we're on the topic, has anyone else come across problems with bluetooth mice. The wheel button doesn't orbit or pan(shift) somehow?
                            I've tried regular and USB mice and they all seem to work.
                            P: ACZero
                            • O Offline
                              otb designworks
                              Try setting your scrollwheel button to 3 in your preferences. I am using a bluetooth Logitech mouse with my Macbook Pro and this is what worked for me. No mouse drivers necessary.
                              Cheers, Chuck
                              OTB Designworks is on Youtube
                              • ToboboT Offline
                                Tobobo
                                I use a mixture of both, to honest i don't really think about it. I just do it.
                                Toby
                                Philippians 4:13
                                • N Offline
                                  not registered yet
                                  Thanks Chuck,
                                  I tried setting the scrollwheel button to 3 and then installing the software later. Both methods didn't work. How frustrating! ๐Ÿ˜
                                  Is your mouse the Logitech V270 Cordless Optical Bluetooth?
                                  Cheers.
                                  P: ACZero
                                    dylan
                                    Slightly off topic, but ACZero that is just the best avatar! ๐Ÿ˜„
                                    http://dmdarchitecture.co.uk/
                                    • N Offline
                                      not registered yet
                                      Thanks Dylan,
                                      I thought our familiar friend needed some new groovy gear and party a little. Might even make him my default dude. ๐Ÿ˜Ž
                                      P: ACZero
