    Unhiding groups
    14 Posts 4 Posters 2.2k Views 4 Watching
      rhankc
      i guess my color scheme is off, when a groups is open, the text is very light. when it is hidden< I cant see anything. Where a square without any writing is, that is a hidden group/component., right click and unhide. The unhide All on the edit menu doesn't work in this scenario either.
      Gaieus, Thank you.
      Hank
        rhankc
        The delete guides will remove guidelines from all depths of the drawing, why won't Unhide All unhide all depths of the drawing?
        Hank
        • GaieusG
          There is a reason for not unhiding geometry within groups/components - this way you can always control the visibility of certain elements without needing to put them on separate leayers than the main entity (group/component) is - that can cause serious confusion at the end.
          I use this a lot when I build some components that should align next to each other in long series and I don't want tle dividing lines to be seen between them - see example below.
          Parapet.skp
          • syburnS
            syburn
            what sorts od situation warrant nested groups? just a curious newbie Q.
            P: syburn
              rhankc
              Gaieus, I see your metric parapet, and I unhid the geometry, and understand, i was using hide to make a complex model easier to see while I work.
              I am working on a model of a house, and the roof is in several groups. Instead of invoking sections to work on the uppermost floor plan I found just clicking on the roof and hiding was an easy way to effectivly work on the second floor; Alternatively, to work on the floor below I could hide the upper floor entities and have excellent visibility if everything in the next floor below.
              I was using it to navighate the model, and I do appreciate that the unhide all has reserves, but if you have a situation like mine you jhave to have the previous sequence of groups on to restore the hidden one(s).
              Syburn: though I learned a very good reason for using the components instead of groups yesterday: A floor system would be a good example for nesting, You have the perimeter thickness as a group, plywood or subfloor can be a group, structural members can be a group...
              another good example would be a custom shower, I used nested components instead, floor pan is component 1, the bench is component 2, the door and glass surround is component 3, the fixtures component 4...
              but themaster component would be the first one drawn..the floor pan, it would contain the others, or you could arrange them all on the same level and component all the components...I jsut seem to go deep as I add detail, the groups/components get added.
              I bet there is a lot better way to do it though.
              Hank
                rhankc
                Gaieus, The metric parapet...? what is that? the base is 100.000cm I have been teaching my daughter the metric system this week, and I want to show her the size of the numbers you are using, and the mm, cm usage. thanks
                nevermind. I see the decimal is 3 places to the left. I took that as a comma, I need some specticles.
                Hank
                • GaieusG
                  I just put the parapet together without thinking of the size πŸ˜„
                  Obviously it would be too small for a "real" parapet...
                  Yes, I usually work with 3 decimals at the end and in centimetres - thats how we teke the measurements in the field so the most convenient for me.
                    rhankc
                    Gaieus, thanks for explaining, I didnt mean to critique you drawing... my edited psot didnt read right and I didnt couldn't re-write the whole thing.
                    Anyway, I showed it to my daughter, was able to reinterate a useful metric lesson, and showed her where you were from on GE, You live in a very culturally rich, and architecturally inspired place.
                    Hopefully, someone will offer a method to unhide nested geometry?
                    Hank
                    • boofredlayB
                      boofredlay
                      @rhankc said:
                      ...Hopefully, someone will offer a method to unhide nested geometry?
                      Hank, the best way is to use the Outliner. Just expand your components there, see what is hidden then right click and choose Unhide.
                      http://www.sketchucation.com/forums/scf/sas/Newbie/Nested1.jpg
                        rhankc
                        on mine the light gray is open
                        Hank
                        • boofredlayB
                          boofredlay
                          Ok, here is a better example. The top 5 in the nested group are hidden. Select those, or one, and right click - Unhide.
                          And yes Tom (tomsdesk) I am using your shrubbies πŸ’š
                          http://www.sketchucation.com/forums/scf/sas/Newbie/Nested2.jpg
                            rhankc
                            Really appreciate it Eric,
                            I see the difference on your screenie,
                            For one, I see I need better outliner management, and I was just checking out the old @last tuts; They show having a hidden component category, and physically dragging the selection you want to hide under that heading. I kinda like this idea, so I will know exactly where that hidden label is, when I want to be sure all are on, I'll definately be paying better attention to all these points. I cant hardly get them all back on after hiding. There is one component that stays on in the curtrent job that after hiding all the rest, if I don't pick on the last remaining component, the others wont come back.
                            Hank
