    Sunflow's exporter
    28 Posts 3 Posters 5.9k Views 3 Watching
    • I Offline
      ilay7k
      Hello Kwistenbiebel!
      I have same errors.
      Nice w.i.p.-render, sunflow has instacing-structure like 3dsmax's proxy and i like it.
      Indigo is alternave to Maxwell render/fryrender
      I think sunflow - vray-killer πŸ˜„)))...too
      PS
      I am from vray4skp-forum too.
      • I Offline
        ilay7k
        Didier i read(fro s~r's forum) about new version of su2sf.
        Can you share it?
        • Didier BurD Offline
          Didier Bur
          Yes, it will be uploaded here tomorrow (now upload facility on the SF forum 😞 ).
          Don't expect too much with this one because it is in its early stage of development πŸ˜‰
          DB
          • I Offline
            ilay7k
            Hello Didier! It's great news.
            In any case, thank you!
            ilay
              Didier Bur
              The update is here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1514
              Also available at my site, "Files-Converters-Misc" section.
              Regards,
              DB
              • I Offline
                ilay7k
                Thanks a'lot!!!
                But some errors are appeared...
                Error; #<TypeError; cannot convert Fixnum into String>
                su2sf.rb;81;in `+'
                su2sf.rb;81;in `output_image_settings'
                su2sf.rb;728;in `export'
                su2sf.rb;793
                su2sf.rb;793;in `call'
                when i change render-settings(Antialiasing).
                  Didier Bur
                  Fixed (uploaded at the same place) 😳 . Sorry for the inconvenience and thanks for reporting,
                  DB
                  • I Offline
                    ilay7k
                    Didier, thanks for fix!
                    So i try it.
                    sunflow render works fine with outdoor models.
                    But indoor...error appears about sky-light(about photon-emiting)
                    http://www.sketchucation.com/forums/scf/sas/Ruby/variants1.jpg
                      Didier Bur
                      Path tracing need emitting light to shoot photons (afaik). So when you select "solid color" as background there's no sunsky, thus no light to emit. Same occurs outdoor too.
                      DB
                      • I Offline
                        ilay7k
                        Thank you!
                        I understand it(outdoor scences are only tests)
                        I trying to render indoor scences like - http://rapidshare.com/files/45915944/sb1_sf.rar.html
                        I also try to "play" with different settings of gi-types
                        For example, i use "standard" ui-setting:
                        1. render-sett.: res.- 800x600; gi - high; aa- none
                        2. background sett.: bg type - sky
                          and when i render and start-up message about "photon mapping enabled, but no globals photons to emit". it's for light-object
                          Ilay
                        P.S. maybe some technical questions are asked on official forum?
                          Didier Bur
                          I suppose that when one is indoor and the sunsky is not visible (no openings to the outside) and when there is no light inside the room, SF considers that there are no photons to emit ?
                          I'm not familiar enough yet with SF to be sure of that. Maybe you could ask Eugene or fpsunflower at the official forum.
                          Cheers,
                          DB
                          • I Offline
                            ilay7k
                            Ok! I ask.
                            I try to illuminate by one light - "sky+sun" - sky-object(for daylighting)
                            Ohhh, Didier! What are you think about simulated(artificial) lighting?
                            maybe it' like materials, only to group = sf-"light.name_group".
                            Sorry for my bad English, my russian is native.
                              Didier Bur
                              Artificial lighting will be supported in next release (point light, spot, and so on).
                              DB
                              • I Offline
                                ilay7k
                                I test AO-settings
                                http://img411.imageshack.us/img411/7990/testaorj6.th.jpg
                                  Didier Bur
                                  Hi all,
                                  When coding the SketchUp2SF plugin, I started to experiment shaders.
                                  These first experiments can be downloaded as a library here:
                                  http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Sunflow/thumb.html
                                  Or go to my site and click on the Sunflow Shaders menu.
                                  Enjoy,
                                  DB
                                  • I Offline
                                    ilay7k
                                    Didier, it's great! Thank you
                                    Do you work at material editor or something?
                                      Didier Bur
                                      No,
                                      I'm just trying to get good parameters mainly for diffuse and glass shaders to implement the SU materials convertion in the plugin.
                                      Cheers,
                                      P.S.: Be back 08.25 (holidays πŸ˜› )
                                      DB
                                      • I Offline
                                        ilay7k
                                        Have a nice holidays. I glad for you, I will be working from 02.08
                                        It's handly, writing into .sc? Or ...
