    Sunflow's exporter
    28 Posts 3 Posters 6.7k Views 3 Watching
    • K
      kwistenbiebel
      Hi all,
      I am trying sunflow out on a test model.
      This is the first output I get after pushing 'render' in the Sunflow GUI.
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/testsunflow.jpg
      As you can see, there is direct light but the indirect light needs more bounces/trace depth.
      I tried to find a way to change that but I couldn't find how.
      Searching on Sunflow forum, I found code lines but I can't seem to be able to use the ctrlC+ctrlV (copy-paste) command to enter it in the' script editor' of the Sunflow editor.
      What am I doing wrong.
      Should I be editing the .sc file (it's HUGH !) or instead put code in the 'script' editor.
      Where can I change the presets like resolution, GI settings, etc...?
      I tried reading briefly through the Sunflow forum but couldn't find the answers.
      Could someone give me a hand to get started with this?
      Thanks in advance,
      Kwistenbiebel
      • I
        ilay7k
        @kwistenbiebel said:
        Hi all,
        Thanks in advance,
        Kwistenbiebel
        Kwistenbiebel look at cornell_box_jensen.sc or julia.sc from examples
        you can download from off.site of sunflow render.
        but need add some modification to lights or mats
        -------julia.sc
        gi { type path samples 16 }
        light {
          type spherical
          color { "sRGB nonlinear" 1 1 .6 }
        radiance 60  <----------for gi
          center -5 7 5
          radius 2
          samples 8
        from cornell_box_jensen.sc
        trace-depths {
          diff 4
          refl 3
          refr 2
        photons {
          caustics 1000000 kd 100 0.5
        % uncomment this block and comment the following GI block to switch gi engines
        %% use these to view the effect of the individual gi components
        % override debug_caustics false
        % override debug_globals false
        % override debug_gi false
        and mat-s had
        shader {
          name debug_caustics
          type view-caustics
        shader {
          name debug_globals
          type view-global
        shader {
          name debug_gi
          type view-irradiance
        • K
          kwistenbiebel
          Thanks Ilay,
          I tried to copy and paste some of those code lines but it produces errors when opening in sunflow.
          Not sure if those lines would just need to be added or they need to replace existing lines.
          My lack of experience in using code lines makes this somewhat too hard 😳 .
          This is the result from a 'default' SU2Sunflow export.(render time ca. 4 minutes 1600X1200 )
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/test2-1.jpg
          I can see Sunflow has potential when looking at the gallery section.
          Hoping to see a full blown Sketchup plugin soon.
          Regards,
          Kwistenbiebel
          • I
            ilay7k
            Hello Kwistenbiebel!
            I have same errors.
            Nice w.i.p.-render, sunflow has instacing-structure like 3dsmax's proxy and i like it.
            Indigo is alternave to Maxwell render/fryrender
            I think sunflow - vray-killer πŸ˜„)))...too
            PS
            I am from vray4skp-forum too.
            • I
              ilay7k
              Didier i read(fro s~r's forum) about new version of su2sf.
              Can you share it?
              • Didier BurD
                Didier Bur
                Yes, it will be uploaded here tomorrow (now upload facility on the SF forum 😞 ).
                Don't expect too much with this one because it is in its early stage of development πŸ˜‰
                DB
                • I
                  ilay7k
                  Hello Didier! It's great news.
                  In any case, thank you!
                  ilay
                  • Didier BurD
                    Didier Bur
                    The update is here:
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1514
                    Also available at my site, "Files-Converters-Misc" section.
                    Regards,
                    DB
                    • I
                      ilay7k
                      Thanks a'lot!!!
                      But some errors are appeared...
                      Error; #<TypeError; cannot convert Fixnum into String>
                      su2sf.rb;81;in `+'
                      su2sf.rb;81;in `output_image_settings'
                      su2sf.rb;728;in `export'
                      su2sf.rb;793
                      su2sf.rb;793;in `call'
                      when i change render-settings(Antialiasing).
                      • Didier BurD
                        Didier Bur
                        Fixed (uploaded at the same place) 😳 . Sorry for the inconvenience and thanks for reporting,
                        DB
                        • I
                          ilay7k
                          Didier, thanks for fix!
                          So i try it.
                          sunflow render works fine with outdoor models.
                          But indoor...error appears about sky-light(about photon-emiting)
                          http://www.sketchucation.com/forums/scf/sas/Ruby/variants1.jpg
                          • Didier BurD
                            Didier Bur
                            Path tracing need emitting light to shoot photons (afaik). So when you select "solid color" as background there's no sunsky, thus no light to emit. Same occurs outdoor too.
                            DB
                            • I
                              ilay7k
                              Thank you!
                              I understand it(outdoor scences are only tests)
                              I trying to render indoor scences like - http://rapidshare.com/files/45915944/sb1_sf.rar.html
                              I also try to "play" with different settings of gi-types
                              For example, i use "standard" ui-setting:
                              1. render-sett.: res.- 800x600; gi - high; aa- none
                              2. background sett.: bg type - sky
                                and when i render and start-up message about "photon mapping enabled, but no globals photons to emit". it's for light-object
                                Ilay
                              P.S. maybe some technical questions are asked on official forum?
                              • Didier BurD
                                Didier Bur
                                I suppose that when one is indoor and the sunsky is not visible (no openings to the outside) and when there is no light inside the room, SF considers that there are no photons to emit ?
                                I'm not familiar enough yet with SF to be sure of that. Maybe you could ask Eugene or fpsunflower at the official forum.
                                Cheers,
                                DB
                                • I
                                  ilay7k
                                  Ok! I ask.
                                  I try to illuminate by one light - "sky+sun" - sky-object(for daylighting)
                                  Ohhh, Didier! What are you think about simulated(artificial) lighting?
                                  maybe it' like materials, only to group = sf-"light.name_group".
                                  Sorry for my bad English, my russian is native.
                                  • Didier BurD
                                    Didier Bur
                                    Artificial lighting will be supported in next release (point light, spot, and so on).
                                    DB
                                    • I
                                      ilay7k
                                      I test AO-settings
                                      http://img411.imageshack.us/img411/7990/testaorj6.th.jpg
                                      • Didier BurD
                                        Didier Bur
                                        Hi all,
                                        When coding the SketchUp2SF plugin, I started to experiment shaders.
                                        These first experiments can be downloaded as a library here:
                                        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Sunflow/thumb.html
                                        Or go to my site and click on the Sunflow Shaders menu.
                                        Enjoy,
                                        DB
                                        • I
                                          ilay7k
                                          Didier, it's great! Thank you
                                          Do you work at material editor or something?
                                          • Didier BurD
                                            Didier Bur
                                            No,
                                            I'm just trying to get good parameters mainly for diffuse and glass shaders to implement the SU materials convertion in the plugin.
                                            Cheers,
                                            P.S.: Be back 08.25 (holidays πŸ˜› )
                                            DB
