    Sunflow's exporter
    28 Posts 3 Posters 6.3k Views 3 Watching
    • Didier BurD Offline
      Didier Bur
      In manual - http://www.geneome.net/other/otherfiles ... manual.pdf
      we have definitions about TEXTURED SHADERS.
      Yes I know that but every face must have UV values to be correctly rendered with such shaders. So it is impossible for now to achieve that, starting from a SU model in which 99% of faces DON'T have UV's 😠
      DB
      • I Offline
        ilay7k
        Thank you, Didier!
        GSU's dev.team, you need to make more "comfortable" functions of UV-mapping!!!
        • I Offline
          ilay7k
          I try to find sunflow render version 07.3 and found it...
          If you haven't, try this http://rapidshare.com/files/44324513/sunflow07_3.zip.html
            kwistenbiebel
            Hi all,
            I am trying sunflow out on a test model.
            This is the first output I get after pushing 'render' in the Sunflow GUI.
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/testsunflow.jpg
            As you can see, there is direct light but the indirect light needs more bounces/trace depth.
            I tried to find a way to change that but I couldn't find how.
            Searching on Sunflow forum, I found code lines but I can't seem to be able to use the ctrlC+ctrlV (copy-paste) command to enter it in the' script editor' of the Sunflow editor.
            What am I doing wrong.
            Should I be editing the .sc file (it's HUGH !) or instead put code in the 'script' editor.
            Where can I change the presets like resolution, GI settings, etc...?
            I tried reading briefly through the Sunflow forum but couldn't find the answers.
            Could someone give me a hand to get started with this?
            Thanks in advance,
            Kwistenbiebel
            • I Offline
              ilay7k
              @kwistenbiebel said:
              Hi all,
              Thanks in advance,
              Kwistenbiebel
              Kwistenbiebel look at cornell_box_jensen.sc or julia.sc from examples
              you can download from off.site of sunflow render.
              but need add some modification to lights or mats
              -------julia.sc
              gi { type path samples 16 }
              light {
                type spherical
                color { "sRGB nonlinear" 1 1 .6 }
              radiance 60  <----------for gi
                center -5 7 5
                radius 2
                samples 8
              from cornell_box_jensen.sc
              trace-depths {
                diff 4
                refl 3
                refr 2
              photons {
                caustics 1000000 kd 100 0.5
              % uncomment this block and comment the following GI block to switch gi engines
              %% use these to view the effect of the individual gi components
              % override debug_caustics false
              % override debug_globals false
              % override debug_gi false
              and mat-s had
              shader {
                name debug_caustics
                type view-caustics
              shader {
                name debug_globals
                type view-global
              shader {
                name debug_gi
                type view-irradiance
                kwistenbiebel
                Thanks Ilay,
                I tried to copy and paste some of those code lines but it produces errors when opening in sunflow.
                Not sure if those lines would just need to be added or they need to replace existing lines.
                My lack of experience in using code lines makes this somewhat too hard 😳 .
                This is the result from a 'default' SU2Sunflow export.(render time ca. 4 minutes 1600X1200 )
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/test2-1.jpg
                I can see Sunflow has potential when looking at the gallery section.
                Hoping to see a full blown Sketchup plugin soon.
                Regards,
                Kwistenbiebel
                • I Offline
                  ilay7k
                  Hello Kwistenbiebel!
                  I have same errors.
                  Nice w.i.p.-render, sunflow has instacing-structure like 3dsmax's proxy and i like it.
                  Indigo is alternave to Maxwell render/fryrender
                  I think sunflow - vray-killer πŸ˜„)))...too
                  PS
                  I am from vray4skp-forum too.
                  • I Offline
                    ilay7k
                    Didier i read(fro s~r's forum) about new version of su2sf.
                    Can you share it?
                      Didier Bur
                      Yes, it will be uploaded here tomorrow (now upload facility on the SF forum 😞 ).
                      Don't expect too much with this one because it is in its early stage of development πŸ˜‰
                      DB
                      • I Offline
                        ilay7k
                        Hello Didier! It's great news.
                        In any case, thank you!
                        ilay
                          Didier Bur
                          The update is here:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1514
                          Also available at my site, "Files-Converters-Misc" section.
                          Regards,
                          DB
                          • I Offline
                            ilay7k
                            Thanks a'lot!!!
                            But some errors are appeared...
                            Error; #<TypeError; cannot convert Fixnum into String>
                            su2sf.rb;81;in `+'
                            su2sf.rb;81;in `output_image_settings'
                            su2sf.rb;728;in `export'
                            su2sf.rb;793
                            su2sf.rb;793;in `call'
                            when i change render-settings(Antialiasing).
                              Didier Bur
                              Fixed (uploaded at the same place) 😳 . Sorry for the inconvenience and thanks for reporting,
                              DB
                              • I Offline
                                ilay7k
                                Didier, thanks for fix!
                                So i try it.
                                sunflow render works fine with outdoor models.
                                But indoor...error appears about sky-light(about photon-emiting)
                                http://www.sketchucation.com/forums/scf/sas/Ruby/variants1.jpg
                                  Didier Bur
                                  Path tracing need emitting light to shoot photons (afaik). So when you select "solid color" as background there's no sunsky, thus no light to emit. Same occurs outdoor too.
                                  DB
                                  • I Offline
                                    ilay7k
                                    Thank you!
                                    I understand it(outdoor scences are only tests)
                                    I trying to render indoor scences like - http://rapidshare.com/files/45915944/sb1_sf.rar.html
                                    I also try to "play" with different settings of gi-types
                                    For example, i use "standard" ui-setting:
                                    1. render-sett.: res.- 800x600; gi - high; aa- none
                                    2. background sett.: bg type - sky
                                      and when i render and start-up message about "photon mapping enabled, but no globals photons to emit". it's for light-object
                                      Ilay
                                    P.S. maybe some technical questions are asked on official forum?
                                      Didier Bur
                                      I suppose that when one is indoor and the sunsky is not visible (no openings to the outside) and when there is no light inside the room, SF considers that there are no photons to emit ?
                                      I'm not familiar enough yet with SF to be sure of that. Maybe you could ask Eugene or fpsunflower at the official forum.
                                      Cheers,
                                      DB
                                      • I Offline
                                        ilay7k
                                        Ok! I ask.
                                        I try to illuminate by one light - "sky+sun" - sky-object(for daylighting)
                                        Ohhh, Didier! What are you think about simulated(artificial) lighting?
                                        maybe it' like materials, only to group = sf-"light.name_group".
                                        Sorry for my bad English, my russian is native.
                                          Didier Bur
                                          Artificial lighting will be supported in next release (point light, spot, and so on).
                                          DB
                                          • I Offline
                                            ilay7k
                                            I test AO-settings
                                            http://img411.imageshack.us/img411/7990/testaorj6.th.jpg
