    Cloud.rb update
    23 Posts 9 Posters 6.4k Views 9 Watching
    • Didier BurD Offline
      Didier Bur
      Dave,
      You're right, there shouldn't be any CR at line end.
      Just like this:
      0,8,7
      2,3.1,5
      and so on.
      Please send me the file just to check what's wrong with it. 😒
      Excel CSV, Notepad, Wordpad, UltraEdit, Shalom, deliver correct ascii text files.
      You can display and/or supress all unwanted CR with a lot of common text editors, for instance SciTE (see pic with regular carriage returns and line feeds on).
      Hope this helps,
      http://www.sketchucation.com/forums/scf/sas/Ruby/scite.gif
      DB
        Didier, I sent you an e-mail. Thanks.
          Didier,
          I seem to be experiencing the same problem as Dave. I use Notepad++ and there is no such problem with SU 5 and the previous version of your script. In the "Line sample..." of the dialogue box there is that edn character though, as well, and the script does not create any point cloud.
          • E Offline
            ELYSIUM
            Hi all!
            I'm making a model of the roman forum, and i have found the geospacial data of most of its buildings on this site:
            http://dlib.etc.ucla.edu/projects/Forum/geospatial
            Is this the sort of data that this script uses? and can anyone help me with converting these into a skp file??
            tks.
              Hi Pedro (not mistaken?)!
              Yes, exactly this is the script you could use.
              I went to the link you provided, copied the data and inserted it into a plain text editor. There you need to get rid of the tab signs and the double spaces only and you're ready to convert your data file (a plain text file) into a cloud of points.
              I only have this problem with getting the script to work. The previous version worked well on my SU5 but now there seems to be some problem - maybe with the ending character at the end of each line.
              Didier posted a pdf file, too, on the "how-to"s of the script. Please, read it and see the details.
                Ben Ritter
                Didier,
                Thank you so much for the script.
                When I tried it, the triangulated data (.csv file) came in at about 45 degrees to horizontal. Any ideas why?
                Ben
                  Didier Bur
                  Yes there sure is a bug remaining in the script when used with V6.
                  I MUST find it (as soon as I have V6 installed). For some reason I cannot download it from the Google site, because I have installed it one time, then uninstalled, and now nothing works when I install it again, it says it is v5.2.061 or something. 😡 👿 😡
                  Good someone PLEEEAAASE provide me a link where I can download the free v6 installer ? But not the official link, I have tried it several times with no sucess...
                  I will find the bugs of my scripts ASAP then !
                  Cheers,
                  DB
                  • jujuJ Offline
                    juju
                    I found a link over at filehippo where you can download SU 6.
                      Didier Bur
                      Al laaaaaaast it works !
                      THANKS A BUNCH JUJU 😄
                      I have found what was not really a bug. Option providers have been changed in SU6 so the variable handling your current unit was nil.
                      I will release the updated script tomorrow (I'm home now 😉
                      Regards,
                      DB
                      • E Offline
                        ELYSIUM
                        Tks for your help Gaieus ( right its Pedro 😄 )
                        I'll wait for the new version on the script to try making the cloud.
                          Pedro,
                          I'm so eager to see the new results on your Rome project (how could I have forgotten? 😄)
                          Well Didier, as Juju was quicker, this link (that I prepared for you) does not mean too much any more but still:
                          I uploaded both SU6Pro and SU6 (free) here for you:
                          http://www.gaieus.hu/su/Didier/
                          Have fun and get home quickly!
                            Didier Bur
                            Thanks Gaeius 😛
                            I'll use the free version for now, until I get the Pro french version (it will be released in October, GSU folks are much sloooooower than @Last folks were...).
                            Cloud.rb has been updated (see topic).
                            Have fun,
                            DB
                              Yes, I saw your post - actually, also answered to it - we were just "cross-posting".
                                The new update is now under this topic.
                                I am moving this longer, "discussion-like" thread "back" to the Ruby Forum - leaving only Didier's "final" post in the Ruby Depot to avoid misunderstanding (I myself was confused first when I couldn't find it agai...).
