    Filling gaps in a terrain
    26 Posts 5 Posters 7.5k Views 5 Watching
      dylan
      It is hard to see from this.
      Remember you can adjust the 'Offest' when you stamp. If you adjust it to 0 you may improve things.
      http://dmdarchitecture.co.uk/
      • EdsonE Offline
        Edson
        sorry for the bad image. i have just posted a much better one for you to look at:
        http://www.sketchucation.com/forums/scf/sas/Newbie/clubhouse_det.jpg
        yes, gai, i was editing but perhaps not doing the right thing or not in the correct group.
        dylan, i never heard of being able to adjust the offset.
        thanks.
        edson
        http://www.mahfuz.arq.br
        • EdsonE Offline
          Edson
          dylan,
          i tried to stamp a simple rectangle to check if i could ajust the offset but could not find anywhere the box to enter the offset value. could please guide me through it?
          thanks.
          edson
            dylan
            It is in the VCB (bottom right corner).
            When you choose the face to stamp (bottom of the house) then add the desired offset distance in the vcb before choosing the terrain.
              Edson,
              The same way you can adjust the size of the smoove tool for instance - just type the value and hit Enter.
              A con of this way may be that it sets verticals all around the stamp and you may not want that.
                sorgesu
                You cannot create an offset that is less than 1. I've tried over and over again. It won't allow an offset of 0 just as it won't let you inference the height of the stamped surface with any of the surrounding geometry. Really a problem.
                I would suggest instead to drop in a flat surface and use intersect with selected and remove unwanted geometry after the intersect process.
                Susan Sorger
                Former Seller Hand Rendered Entourage
                Former Canadian Authorized Training Centre, SketchUp
                  dylan
                  I can on my machine Susan, zero works perfectly. Not sure why ours differ.
                  Even if 0 did not work, you could always set 1mm which would not be any real difference.
                  • EdsonE Offline
                    Edson
                    susan, what exactly to you mean by drop in? without using the stamp tool?
                    edson
                      Here's an example:
                      http://www.gaieus.hu/su/pics/terrainexample_thmb.jpg
                      and the skippy
                        sorgesu
                        Funny, I've tried to use an offset of zero on countless different occasions and I couldn't. I just checked and I could.
                        On another thread someone asked about the maximume pixel size of an export and said he couldn't get it past 4000. I said it was 9999 and set out to prove it, and then I couldn't. I tried with 7000 and I couldn't. Tried it with 5000 and I couldn't. Then I tried it with a different model and I had no problem with 7000, didn't try 9999. I wonder what it is at work here, that sometimes an offset of zero works and others it does not?
                        Susan Sorger
                          No, Susan, it's not offsetting here - I've never tried but it would make sense not to be able to do it because then why to at all? (like you cannot scale anything to 0 either). This is the stamp tool in the sandbox: you can adjust the steepness of the connecting sides from the terrain to the flat, stamped surface. By hitting 0 before stamping, you can make it as a pit or a box popping out of the TIN.
                          There are problems however:
                          1. Edson wanted to "dig" his house partly into the hill but obviously did not want a cliff on the other side. You cannot individually adjust the slopes.
                          2. If the sides of the pit I posted were really just verical, they should be coplanar as well and the hidden (actually smoothen) lines could be deleted but this is not the case.
                          So this needs some more examination (and from now on it should rather be in the Pro Forum but Edson posted some similar problem there, too...)
                          As for images, I once tried he extremes and challanged a 9999 pixel wide TIF. You can imagine! πŸ˜„
                          The biggest I needed was 3500 x 3500 pixels but I could not get it with textures and shadows on with AA so I had it with no shadows. The contractor was still happy (he'll eventually get 3DS Max renderings anyway...)
                            sorgesu
                            That's what I'm saying Gaieus, I was never able to before. But today I could. How odd.
                            Susan Sorger
                              Maybe your computer was not hung over today...
                              πŸ˜„
                              It is probably up to the hardware anyway but I don't need too big resolutions now so I don't care. The next will be some 1500x1050 pixel things but that's just a snap for today (I'll need all those section cuts and everything I don't want to bother with now at night).
                              • EdsonE Offline
                                Edson
                                gai, understood perfectly. thanks.
                                however, my first question is still unanswered: how to fill those gaps? or how to add to a rolling surface?
                                regards to all.
                                edson
                                  Edson,
                                  First of all I'd probably turn hidden geometry on, then depending on the nature of the TIN there (which cannot be seen in the pic) there are more possibilities. We'd probably need the skp file to say more (or to fix it).
                                  • EdsonE Offline
                                    Edson
                                    @gaieus said:
                                    Edson,
                                    there you have it: http://www.sketchucation.com/forums/scf/sas/Newbie/terreno_clubhouse.skp
                                      Edson, I restitched the terrain (more or less as it could have been in the original). There are still some lines there - you can delete them if you wish (I did not want because you may still want them). The link to the model
                                      Is this what you wanted?
                                      • EdsonE Offline
                                        Edson
                                        @gaieus said:
                                        Edson, I restitched the terrain. Is this what you wanted?
                                        yes! thank you very much.
                                        could you please tell me how you did it? like they say, better than giving the fish away is teaching how to get it from the sea.
                                        cheers.
                                        edson
                                          Simply hand-stitched. Tried to follow the dotted (smoothed) lines where possible to regain the original terrain - at some places I had to "improvise" though.
                                          • EdsonE Offline
                                            Edson
                                            this thread was very, very helpful. you guys opened my eyes to a number of features that i was not aware of. i had a look at the manual just to make sure i got the whole picture. thank you all.
