    Greene & Greene Thorsen House Inspired Side Table
    12 Posts 6 Posters 2.6k Views 6 Watching
      Here's a side table for you all. I based it on one I found in a magasine. It's pobably too heavy to use as a component in a model. I drew it with all the joinery and used components for the individual parts.
      I guess it could be stripped down to make it light enough to use in larger models.
      Thorsen Side Table.skp
        boofredlay
        Ooo, I like it.
          rhankc
          Thanks Dave, That goes in the Greene&Greene style cottage I'm currently working on.
          Hank
            Daniel
            That is beautiful. Thanks for sharing it.
            My avatar is an anachronism.
              tomsdesk
              Sweeeeeeeeet! You did it again, Dave. Thanks, Tom.
              2.5D Trees & Shrubs!
                Gidon Yuval
                Lovely model, Dave.
                I can understand making a model with all of the joinery as a way of planning out your production process. I do that often so that I can be certain the craftsmen will produce exactly what I want. If I think it's worth posting as a model I usualy make a copy and simplify it as much as I can.
                Is it alright with you if I re-do your model without the joinery and redundant faces? It's a beautiful model but for use as a component it's somewhat over-modeled.
                If you don't know where you're going, you're never going to get there.
                  Gidon Yuval
                  By the way guys, there is now a wood-working sub-forum that you can find at the bottom of the Board index under 'special interest groups'.
                    Gidon, if you want to do it, go right ahead. I generally don't draw furniture with the intent that it'll be used as a component in a larger model. I guess I'd need to modify every one of my pieces before posting them, then.
                      boofredlay
                      Dave, don't worry about modifying your work just for us ๐Ÿ˜ฎ
                      Make what you want to make for you then show it off man. If I were to use this in a job I would probably not modify it a bit. That is unless I were placing hundreds of them, then I might cut the poly count down.
                        I must be blind. I can find Special Interest forums at all.
                          Thanks Eric. FWIW, I do try to keep file sizes down when I make my models. Of course they aren't as small as they could be but they are dimensionally accurate and you could take them apart and make working drawings for your wood shop from them.
                            boofredlay
                            No you are not Dave, the idea was premature and got held off until after the transfer is completed. We will revisit the idea of a WW sub-forum real soon.
                            And that is why I like you to post them ๐Ÿ˜„ The more ways I can learn to build anything with wood the better off I am.
                            Thanks.
